6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Power Steering Issue
Old Aug 25, 2019 | 08:31 AM
99F350bigorange's Avatar
99F350bigorange
So I bought an 08 F350 crew cab 4wd long bed. Had it a week and the belt tensioner broke causing the belt to break. In turn the belt wrapped up around the power steering pump causing it to leak. I replaced the pump and bled the system for hours. No luck. No steering no brakes. Took it to a shop they said I got a bad pump. They replaced the pump, motorcraft pump, they said it was working and bled the system all day replaced the hydroboost and said the steering gear was bad now. I took it home replaced the steering gear. Bled the system for a little over two hours. After replacing basically every part on the power steering system and bleeding the system multiple times I still have no power steering and no brakes. Anyone have any ideas? I'm at a complete loss.
tlb
Mar 20, 2011 09:09 AM
78C_F150_Fevr
Jan 28, 2006 10:48 AM
jcab
Oct 20, 2004 11:18 PM
