Sponsored by: Real Truck
Help with vibration
Old Aug 24, 2019 | 07:21 AM
ReidG's Avatar
ReidG
Help with vibration
Hey all. Got a 2015 F250 Crew cab/long box. Got a vibration that starts at 115km/hr and up. Just put on new Goodyear Duratrac 295/65/18’s. All balanced and 4 wheel alignment. Did not fix the problem. Any ideas?
Old Aug 24, 2019 | 07:32 AM
Deuce40s's Avatar
Deuce40s
That's 71mph in freedom units. At that speed it could be about anything. Can you tell if it's front or rear? If you're sure it's not tires, then it could be the driveshaft slightly out of balance, or slightly worn u-joints.
Old Aug 25, 2019 | 05:41 AM
Gints's Avatar
Gints
Do not do anything before you road force test the wheels. I balanced wheels three times still have vibration exactly at that speed, did road force test and readings was 42, 47, 64, 67 with acceptable being 40. Continental agreed to replace all four of them.
Old Aug 25, 2019 | 06:16 AM
ReidG's Avatar
ReidG
Tires
Was doing it on the old tires as well. Seems to be coming from the front end.
Old Aug 25, 2019 | 07:46 AM
RV_Tech's Avatar
RV_Tech
Agree road force balancing is essential, had same issue with both old and new tires until road forced balanced. IMHO it should be essential with all Super Duty truck tires. Just standard rebalancing did not fix the issue.
Dave042
2009 - 2014 F150
38
Jun 25, 2024 10:35 AM
Justin Jones
28
Aug 8, 2016 01:55 PM
Spruce64
May 4, 2013 06:35 PM
wolfe1104
Aug 24, 2006 09:08 PM
