Remote Start
Old Jan 24, 2020 | 08:56 AM
BroncoRN's Avatar
BroncoRN
My truck is the complete opposite. I have the keyfob remote start but not the built in modem. Can the modem be added later? Which part would you have to buy?
Old Jan 24, 2020 | 10:07 AM
Poncho450's Avatar
Poncho450
If you did this, would you be required to carry another cell subscription to the carrier that Ford designates? Seems like I read that one time. Then I also recall seeing that if you purchased a new truck equipped with the modem that it was free for a period of time. Might be worth looking into.
Old Jan 24, 2020 | 10:25 AM
BroncoRN's Avatar
BroncoRN
Is this the part that would be needed?
https://www.getoemparts.com/oem-part...oaAo8uEALw_wcB
Old Jan 24, 2020 | 10:26 AM
h20camper's Avatar
h20camper
From Ford's website:
Service for 2019 vehicles includes a complimentary 2-year trial for remote features. Service for 2020 and later model year vehicles includes a complimentary 1-year trial for remote features, excluding Wi-Fi hotspot, and starts with vehicle sales date (after which, fees apply).
Connected service and related feature functionality is subject to compatible AT&T network availability
Old Jan 24, 2020 | 10:29 AM
Poncho450's Avatar
Poncho450
BroncoRN is considering adding the feature to his truck. I would guess that means paying from the time it's self installed.
Old Jan 24, 2020 | 02:12 PM
Willy Sunshine's Avatar
Willy Sunshine
2019 F-350 Lariat Ultimate diesel crew cab short bed accent color purchased in June, 2019.
i was told the key fob will do remote start. Also told I could down load and configure Ford Pass which would track the truck with gps and start the truck from anywhere. Free for one year, then pay per month. After 2 months I received a letter from Ford saying that in appreciation of me being a good customer, Ford Pass would be free for life of the vehicle.
both types of remote start work very well.
Old Jan 24, 2020 | 10:46 PM
StonedGrey's Avatar
StonedGrey
There have been many threads on this subject.
I recently added remote start to my 18XLT.
I had the hood switch from the factory. Start the truck and pop the hood. If you have the required hood switch, the instrument cluster will say the hood is open/ajar.
If hood switch is present, then adding the Ford remote start / security module under the dash and forscan to activate the system is all thats needed to make the key fob remote start your truck via lock-unlock-lock.
I have tried using the app, but as other have stated, it requires another antenna or piece of hardware. I havent pursued the app starting as I not interested in it & dont need it.
Do a google search for 2017 SD remote start module Fairway Ford. The module is about $170.
Takes 5-10min to easily install into the back of the OBDII port under the drivers side of the dash.
Old Jan 25, 2020 | 10:04 AM
Poncho450's Avatar
Poncho450
I believe this subject or at least the last few posts are about the newer trucks where a factory modem is needed to activate remote start through FordPass.
The system you mention is the older method that used the Ford Remote Access app. I installed that type in both a 2014 and a 2016. I did install the additional antenna and got a bidirectional fob for the times I didn't use the cell phone starting method.
White gold
Mar 24, 2026 08:06 AM
ArtsBest
2009 - 2014 F150
24
May 27, 2025 01:38 AM
Kafn8td
Feb 14, 2014 03:25 PM
marksbrat
General Diesel Discussion
Jan 7, 2006 01:29 PM
