TIRES CUPPING????
Old Aug 23, 2019 | 09:18 PM
INFAMOUS FAME's Avatar
INFAMOUS FAME
TIRES CUPPING????
Anyone having any issues with front tires cupping on there trucks, im running 37's and a 6 inch lift on my 2018 superduty!! Any info on what i should check first?
Old Aug 23, 2019 | 10:37 PM
Magoo22's Avatar
Magoo22
From my experience the biggest cause of cupping on oversized tires is high pressure. Try reducing pressure and do a chalk test to get the optimum number. I run 35x12.5 tires on my truck and 35 psi is working great. Your weight will tell you what is the right pressure. You can also find a dusty or gravel road and look at the contact patch.
Old Aug 23, 2019 | 11:32 PM
DSLTRK60's Avatar
DSLTRK60
What did they do to keep alignment in check? 6 inches is a large change in suspension geometry.
Did they realign to factory specs? Did you get radius arm drop brackets? Did they install caster correction bushings?
All this can effect tire wear.
Old Aug 24, 2019 | 10:51 PM
Wandell877's Avatar
Wandell877
Also, what tires are you running. In my experience, not rotating tires often enough will cause cupping. Mud tires are especially prone to this.
Old Aug 24, 2019 | 11:19 PM
displacement4me's Avatar
displacement4me
Further magnified by driving the 9000lb truck like it’s a car on rails
Old Aug 25, 2019 | 07:52 PM
INFAMOUS FAME
Im going to get an alignment on it tomorrow and have them check that all tires are balanced. I hit a deep pothole a while back and the truck has been pulling a little to the right since then probably not something out of wack. Thanks for all the help and input ill report back once alignment is done!
Old Aug 25, 2019 | 08:14 PM
HRTKD's Avatar
HRTKD
It's not??? You must not have the rear sway bar.
Old Aug 26, 2019 | 06:22 AM
George C's Avatar
George C
My experience is poor shocks cause cupping. Upgrade to something with the strongest damping.
Old Aug 26, 2019 | 11:26 AM
17 Oaks's Avatar
17 Oaks
X99
Cupping first stop is shocks.
May not work on your truck, but on a car, lean over on the L/R front fender and come down hard with all your weight, then release immediately and see if the fender continues to move up and down...weak shock if it does.
Also, look at the shocks to see if there is any leaking fluid on the outside. if so replace ASAP.
Pigman54
Jul 29, 2014 01:23 PM
polcat
Offroad & 4x4
13
Jan 15, 2007 06:37 PM
dhag911
Aug 26, 2005 06:09 PM
new2dsl
Apr 13, 2004 09:54 AM
Mikeman
Aerostar
Mar 15, 2002 10:13 AM
