79 f100 brake pedal
Previous owner swapped in a booster, but the cluck did not know that the brake pedal was different.
D7TZ-2455-B.. Brake Pedal, use with Power Brakes without Speed Control / Marked: D7TA-2455-LA / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
1978 F100 // 1979 F100 before serial number DJ0,001 // 1977 F150 2WD with M/T // 1978 F150 // 1979 F150 before serial number DJ0,001 // 1977 F250/350 with M/T // 1978 F250/350.
1979 F250/350 before serial number DJ0,001 // 1978 Bronco // 1979 Bronco before serial number DJ0,001
D3TA-CA = D3TZ-2455-B .. Brake Pedal - Use with manual brakes: 1973/78 F100 2WD
I'm really glad this post came up, I have a 75 F350 with a pedal that seems too high, it has power brakes but it has the D3TA-CA manual brakes pedal, my pedal is about 7 1/2" from the floor, dont know if that is normal or not, I have had three 73-79 trucks and this is the only one that the pedal seems high.
I am sure NumberDummy can answer your questions but you may need to start your own post with make model an year an last 6 digits of vin
beechkingd
03-18-2009 03:46 AM
psquare7575
21
11-23-2007 11:51 PM
