79 f100 brake pedal
Having issue with pedal height on 79 f100 , as the picture shows it does not come up high enough to make brake switch, I just replaced booster and it all seemed the same , of course I don't remember how it was before disassembling a few years back and don't think pedal was changed before but who knows, anyways is there something I could have done reassembling or is there adjustment to raise ?
https://cimg5.ibsrv.net/gimg/www.for...29868cb46.jpeg |
Have you started it yet ? sometimes you need to let the vacuum pull things in place. if that doesn't do it you might have the wrong booster.
Originally Posted by 440 sixpack
(Post 18815901)
Should mention its 2wd
Provided everything was functioning correctly before you replaced anything, you shouldn't have any issues once you do swap boosters. Are you able to pull the pedal up any further by hand?
Originally Posted by Doosenberry
(Post 18815986)
Gotcha. I've changed out a couple of boosters on my rigs (77 F100, 78 Bronco) and none of them had any issues with pedal travel after the boosters were replaced.
I upgraded my F100 from manual brakes to power brakes and when I did that I had to swap pedal assemblies as manual and power brake pedals are different. If you don't swap them and leave a manual pedal with a power brake setup then your pedal will sit very close to the floor. Maybe the PO did that to your truck? |
(Post 18816015)
My 77 came with front discs and was manual brakes, but again, it's not a 79. Maybe by 79 everything had power brakes.
Originally Posted by 72rtchallenger
(Post 18816028)
Unsure, but truck came with power brakes from what I have deciphered. It's a 79 and unsure if any 79 came with manual brakes or not, as all 79 models were disk brakes to my knowledge.
Of course my knowledge is limited, I have owned several 79 models, all were power brakes and steering. Power disc brake pedal is different than manual disc brake pedal, and there is more than one, especially if it has Speed Control. Look on the brake pedal, there should be a Ford ID engineering number stamped on it (similar to this: D7TA-2455-LA), post what it is. 1979 F100 2WD: A/T or MT? With or without Speed Control? What are the last 6 digits of the VIN? 1973/79 F100/350: There are TWENTY TWO different brake pedals, NINETEEN different master cylinders, SEVENTEEN different boosters, SEVEN different clutch pedals, I kid you not! The booster must match the brake pedal, otherwise... |
(Post 18816061)
1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
Power disc brake pedal is different than manual disc brakes pedal, and there is more than one, especially if it has Speed Control. Look on the brake pedal, there should be a Ford ID engineering number stamped on it (similar to this: D7TA-2455-LA), post what it is. 1979 F100 2WD: A/T or MT? With or without Speed Control? What are the last 6 digits of the VIN? 1973/79 F100/350: There are TWENTY TWO different brake pedals, NINETEEN different master cylinders, SEVENTEEN different boosters, SEVEN different clutch pedals, I kid you not! The booster must match the brake pedal, otherwise... |
(Post 18816113)
You are correct if I read the numbers correctly , best I can see D3TA CA MAN BRK 629 79 could be wrong hard to see installed ,,no speed control vin SIX DE8011
(Post 18816121)
I wonder what MAN BRK stands for. lol :-X22
I'm sure numberdummy will point you in the right direction for finding a power brake pedal assembly. I wonder if it'd be easier to find a pedal assembly and then get a new brake booster/master cylinder that matches the pedal rather than finding a specific pedal for what you already have.
(Post 18816153)
