Rear ABS
Old Aug 23, 2019 | 12:41 PM
troy676's Avatar
troy676
Rear ABS
Im replacing my Open Diff with a Limited Slip Carrier, do I need to reinstall the Reluctor Ring on the Carrier as the Limited Slip Unit does not have it. This truck Does NOT have the ABS Sensors on the Axles, so Im thinking its a redundant item ? '96 Ford Ranger,
Thanks for the Help
Old Aug 23, 2019 | 02:40 PM
troy676's Avatar
troy676
Well Ill answer my own question Looks as tho It has to be there, The PCM is looking for it even tho NO wheel sensors are present,
Old Aug 23, 2019 | 05:43 PM
jhaynos's Avatar
jhaynos
Correct me if I'm wrong, but I believe the speedometer is run from the reluctor
Old Aug 24, 2019 | 06:01 AM
troy676's Avatar
troy676
It very well could be used for that as well. I have to machine the carrier to accept it tho.
Old Aug 24, 2019 | 04:34 PM
00t444e's Avatar
00t444e
You will need that if you want your speedometer to work. What carrier did you get? Most are made so the tone ring will fit.
Old Aug 24, 2019 | 05:12 PM
troy676's Avatar
troy676
'86 T-Bird, had to turn off about 1/16" on the Ring Gear Dia. It's in and all finished now..just have to add lube. Going to be nice to have 2WD in winter.
1998Ranger25L153CID
Jan 21, 2018 07:44 PM
94 ranger tyson
Jan 23, 2010 05:14 PM
Douglas Walker
Dec 20, 2006 06:10 AM
minnesota4x4
Dec 2, 2005 04:24 PM
mike_v2v98
Nov 16, 2002 06:35 PM
