Brake Light Problems
Old Oct 7, 2003 | 08:54 AM
Andysutt's Avatar
Andysutt
Ok... I stripped every wire from my truck except the 3 wires that go from the cab to the tail lights.
My problem is this...
1 wire lights up tail lights, another does right bright light, other does left bright light.
Here is how I have it wired so far....
Power wire to a toggle switch
Toggle switch controls headlights/taillights
From the toggle switch it goes to the High/low switch in the floor.
From that power wire it Ys...
power in to the switch, and the other wire going to the tail lights.
That way when I flip the switch, the taillights are on, and so are headlights
Turn signals I will be wiring to the original switch in the dash
My problem is this:
The way I have it wired.
When I get brake lights... the front 2 turn signals come on but don't flash
I want to illeminate that.
How does Ford do this from the factory?
Sorry about the long post, but I really need help.
Im sure I can figure it out but im stumped at the moment.
I would have used the original switch and all but it was junk, and the wiring under the dash had been spliced and respliced a million times.
Old Oct 7, 2003 | 08:04 PM
cdherman's Avatar
cdherman
Man -- no one seems to be replying. I think you need a wiring diagram, or a new wiring harness, or quite probably BOTH.
Sorry to be so useless to you. Only so much that can be solved and described via "text".
Old Oct 7, 2003 | 08:20 PM
dbc's Avatar
dbc
Ford isolated the brake lights from the turn signals in the turn signal switch lcated in the steering column. Get a diagram. it will show you how.
Old Oct 8, 2003 | 01:12 PM
Andysutt's Avatar
Andysutt
Where could I get a diagram for that?
I only need the turn signal diagram
as everything else I have figured out
I dont want a new harness. as the way I did it... its a new harness
All new wires, all color coded.
The turn signal switch has maybe 6 wires hanging out of it.
I just need to know how to wire up the brake lights with it
If someone could send me a diagram or even make one in paint, Id appreciate it.
Old Oct 9, 2003 | 06:17 AM
grandaddy's66's Avatar
grandaddy's66
Andy, (and anybody needing wiring help)
If you want to buy a diagram, go to www.ClassicCarWiring.com. They have AWESOME diagrams, man; easy to read, color coded, cheap. Magic.
I got the 11x17 one. It's like a Leatherman; once I got it, I don't know how I lived without it.
Old Oct 9, 2003 | 12:39 PM
Andysutt's Avatar
Andysutt
I really didnt want to purchase one just for brake lights
but I may have to.... call me cheap. lol
But Im trying to get a roll pan for my truck as it is.
I was going to put 4 lights in it... Now I know how I'll do it
Instead of wiring the turn signals and taillights together
I'll put Outermost lights as running lights/turn signals
and the inner 2 as brake lights
Thats if I get around to a roll pan
Thanks for the link tho.
I'll try again before i purchase a diagram
Old Oct 9, 2003 | 04:16 PM
dbc's Avatar
dbc
Did you search the archives?
https://www.ford-trucks.com/articles...elecrepair.php
Old Oct 9, 2003 | 04:25 PM
Andysutt's Avatar
Andysutt
Thanks. this is what i was needing to know. Maybe I can wire it up right agian
There are 7 wires to the turn signal switch, here is a description of each:
Blue/yellow stripe: horn.
Blue: +12V power from turn flasher for turn signals
Black/red stripe: +12V power from stop lamp switch for stop lamps
Green: Rear right turn/stop lamp
White/Blue stripe: Front right turn lamp
Yellow/black stripe: Rear left turn/stop lamp
Green/white stripe: Front left turn lamp
Old Oct 9, 2003 | 08:39 PM
airharley's Avatar
airharley
Well for $6 or so you can buy one from this site.
Old Oct 9, 2003 | 08:40 PM
Andysutt's Avatar
Andysutt
Hrm, didn't thin it was that low, but I didnt look :P
*thwaps self in head"
Thansk Airharley
Old Nov 5, 2003 | 07:32 AM
1nutman2's Avatar
1nutman2
i needed advice as to why tail lights not working or oncan anyone please help?
Old Nov 5, 2003 | 12:00 PM
Andysutt's Avatar
Andysutt
Bad ground maybe?
or blown bulbs?
Prob something pretty simple if its just the tail lights not working
Old Nov 5, 2003 | 05:51 PM
1nutman2's Avatar
1nutman2
thanks for your reply rewired into tag liite wire worka besides my
post ha wrong year for explorere was 96 thankyou agin for reply
Old Nov 5, 2003 | 07:14 PM
Andysutt's Avatar
Andysutt
Do what?
