Coolant Flush
Old Aug 21, 2019 | 10:10 PM
guessrow's Avatar
guessrow
Coolant Flush
Hello,
I have a 2013 F-150 (5.0) that I am working on flushing the coolant. On previous vehicles, after draining coolant, I was able to flush by removing the top radiator hose. Then I would just keep the radiator filled with tap water and the water that was circulating throughout the system came out the top radiator hose completing the process. The hoses on my 2013 are kind of mixed up so I can't do that... I've flushed it with tap water, ran it with radiator cleaner, flushed that with some distilled water- that part is good; I have my system filled with new distilled water.
BUT NOW WHAT? Draining the radiator and fill tank with the petcock on the radiator only drains out about 6 quarts of water... Id like to drain out 9 quarts or so. That way I can refill with concentrate and have a 50:50 mix or stronger with the remaining distilled water in the system. how can I get an additional 3+ quarts out of the cooling system? Is there a plug on the block to drain out a little more? I'm tempted to replace the thermostat just so i can pressurize the system with air and hopefully blow a few more quarts out...
Helllp!
good luck -jim
Old Aug 22, 2019 | 12:30 PM
pdqford's Avatar
pdqford
Open up one of the block drains.
You’ll be surprised at how dirty the coolant is that is still in the lower block!
Old Aug 22, 2019 | 12:55 PM
guessrow's Avatar
guessrow
Thanks- I've been looking (online and on my truck) but don't see one. Where is the plug?
Old Aug 22, 2019 | 01:29 PM
steve(ill)'s Avatar
steve(ill)
I flushed mine with distilled water... Coolant looked pretty good to start with, but I think it was original and 6 years old... I drained out 6 quarts and added water ... ran motor 3-4 mintues, then drained out 6 quarts and added water..... did this about 4 times.. Check freeze point each time... -40 then -20 , then -5 , then 20 , then 32..... At this point it is half full of distilled water, so I put 6 quarts of 100% antifreeze in it... Ran a day and the freeze point was around -10 ... Drained out 6 quarts and added 6 quarts 100% antifreeze and that did the trick.
Old Aug 22, 2019 | 01:40 PM
ford390gashog's Avatar
ford390gashog
Skip trying to get to the block drains. Use a shop vacuum on the lower radiator hose and you will pull the majority out. Or the other way we cheat at work is to use compressed air on the degas tank and push out the old to the disconnected lower hose.
Old Aug 22, 2019 | 02:34 PM
guessrow's Avatar
guessrow
Thanks...
I'm happy with the flush- My flushing procedure has been to open the petcock to drain the water while refilling continuously with new water with the engine running. The water draining out the petcock was good and warm, so I know at least some of it had circulated through the block. Last time around I repeated with 6 gallons of distilled water. I ran it up to operating temperature and drained 6 quarts from the radiator and degas bottle. I captured some of it in a class and it was crystal clear.
Now I just need to get an extra 3 quarts out. I have blown in the degas tank. but didn't get much more... I will try vacuuming next...
Old Aug 22, 2019 | 05:40 PM
rbentnail's Avatar
rbentnail
I lucked out- last spring my local dealership had a flush and refill special- $74 plus $25 for the second gallon of antifreeze. IIRC the total system capacity is about 17 qts. for the 5.0 so for that price it was worth it to let them do it.
Old Aug 22, 2019 | 09:00 PM
guessrow's Avatar
guessrow
Well... I drained it again after work. This time I unhooked the radiator lines and sucked and blew with my shop vac and pushed some more water out. This time I got a little over 9 quarts of distilled water into it. The last 11 gallons of water for flushes/refills/etc have been distilled water and the coolant is crystal clear when I drain it. I will drain one more time over the weekend, blow and suck one more time and hopefully put in 9 or 10 quarts of concentrated coolant and call it a win. Thanks for the help!
Next up is the front diff. I'm going to suck the oil out of the fill hole with a hose and hopefully get a majority of it before refilling. The only fluid left to change will be the transfer case
good luck -jim
Old Aug 22, 2019 | 09:35 PM
ford390gashog
FYI don't panic when you do the front diff and see its milky. It's not water, it's the assembly lube they have used since 2004. Some people panic but it's for nothing.
Aune163rd
Jan 6, 2011 10:05 PM
97ExpGuy
Apr 23, 2009 10:01 AM
xplorerboy
Sep 5, 2008 11:59 PM
stan v
Aug 7, 2005 07:04 PM
