Power Steering pressure hose swivel?
What year is the truck? 1973/77 uses a different P/S pump and pressure hose than 1978/79.
1973/77: Ford/Thompson "pencil neck" pump has a steel reservoir. The P/S pressure hose threads onto the pump.
1978/79: Ford C-II pump has a plastic reservoir. The P/S pressure hose connects to the pump with a qwik connect fitting.
Mine is a 78 as well, and like yours, literally a Frankenstein. It's got parts from 67 through 96 *******ized onto it, and nothing, absolutely nothing looks like the catalog pictures when I go to order stuff for "1978 Ford f250 supercab"
The exact same thing happened to me. Pressure hose blew apart, ordered the correct hose, and like usual, if course it looked NOTHING like what I'd taken off. And mine was seized in the PS box. Had to cut it off and put a socket and heat on it. Did NOT swivel.
The new hose fit better than the old one, and now swivels as designed for the flex of the motor. No leaks, clears radiator hose and PS belt far better than my old one.
You're going to be OK.
Guys, I have a 78 f-150 4x4 and so far it has been 100% stock to the best of my knowledge. I am having power steering issues as well and working on bleeding it to determine if its the pump pr whatever. Anyway I was looking at the hoses etc. last night and noticed the pressure hose seemed loose. I tightened the fitting and the movement still exists and the hose doesn't leak. I assumed this is per design to allow for engine movement.
jakeharp
11-28-2016 12:36 PM
78f3504x4
15
07-02-2011 06:29 AM
Gary E
05-22-2008 09:29 PM
dynamic
08-02-2007 07:11 PM
JoeBlow
01-01-2005 04:46 PM
