Stalling at high speed
Old Aug 19, 2019 | 11:39 AM
dibbs3232's Avatar
dibbs3232
I have an 03 6.0 dually I have a problem with the stalling under a load. It runs great until I reach 70 mph and hit over 2k rpm. Then the pedal seems to lag and sometimes goes dead. I replaced both fuel filters and not much better result. If I stop the truck an put in park rev it up the lag goes away and won’t come back till truck hits over 70 mph and over 2k rpm. Any ideas? Thank you in advance. I’ve read these forums for help and have seen great info so I joined today to see if there is any advice.
Old Aug 19, 2019 | 03:37 PM
Striderwv's Avatar
Striderwv
Welcome
Need some more truck info if you got it, and did you use motorcraft filters? Can you get us some DTC's and PID readings? I use FORScan (free for windows and $7 for a smartphone) and a BAFX wifi obdii adapter ($27).
Old Aug 19, 2019 | 04:37 PM
dibbs3232's Avatar
dibbs3232
I used micro guard filters I’ll get the readings as soon as I can.
Old Aug 19, 2019 | 05:39 PM
dibbs3232's Avatar
dibbs3232
Other then the scans you asked for any other info you looking for?
Old Aug 19, 2019 | 08:09 PM
Striderwv's Avatar
Striderwv
  • any modifications or all stock
  • look over the engine very closely, any broken or chafed wires, are the cac boots oily or torn, anything not looking right
  • when the pedal goes limp are you gradually running up to 70 mph or are you wot
  • any maintenance performed, you should use motorcraft or racor filters in your truck
  • any fuel, oil or air leaks
  • too much info is better than not enough
  • do you have a motorcraft oil filter and oem cap
Old Aug 19, 2019 | 09:01 PM
vfelix702's Avatar
vfelix702
check static and fuel pressure under WOT
Old Aug 19, 2019 | 09:11 PM
dibbs3232's Avatar
dibbs3232
The visual inspection of the motor and wiring doesn’t turn up anything suspicious. The truck is stock tuned. Other than a few bulletproof upgrades. The HPOP headbolts ficm, ipr valve and the icon are all under a year old. Just replaced the egr valve a few days ago. It has its regular maintenance oil changes filter changes, air and fuel too. The truck doesn’t seem to care how you get to the 70 mph 2k rpm mark. You can mash the gas and get there quickly or gradually get there, the results are the same.you can go past 2k rpm while under load just not after 70 mph. No tuner no visible oil leaks. Oil lvl stays constant.I removed my bed to make accessing underneath easier. Fuel pressure at idle is 48 I have not tested it yet under load.
Old Aug 19, 2019 | 09:49 PM
vfelix702's Avatar
vfelix702
I had same issue static 50 and under wot sucked to 0 just like that..... did blue spring up grade never dropped under 60 or so at wot... just a thought
Old Aug 20, 2019 | 02:09 AM
bismic's Avatar
bismic
Get and post the engine data as you approach the conditions in which the engine shuts down.
Fuel pressure
ICP pressure and volts
IPR % duty cycle
FICM MPower
FICM LPower
FICM VPower
v-reference voltage
tranprop
1997 - 2003 F150
Sep 26, 2010 12:12 PM
CruiserClass
Nov 28, 2009 08:39 AM
bryanswens
Jul 7, 2009 01:30 AM
