Slight RPM bounce
Old Nov 23, 2009 | 06:56 PM
CruiserClass's Avatar
CruiserClass
Slight RPM bounce
My truck is starting to "bounce" a bit during light acceleration and at certain speeds. Holding a steady 40 or so on flat ground and 45 on an incline. The truck maintains speed fine and I don't think its actually shifting, but maybe the TC is locking/unlocking? The RPMS fluctuate slightly, but noticably both by feel and by the tach.
It never does it under hard acceleration or at very low speeds or highway speeds.
Old Nov 24, 2009 | 05:37 PM
CruiserClass
Bueller? Bueller?
Old Nov 24, 2009 | 09:19 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
No idea, but here's a bump.
Old Nov 25, 2009 | 04:01 PM
BigJake34452's Avatar
BigJake34452
heres a bump for ya, i dont think this is a TC issue because i have almost the same exact problem but i got a 6 speed..
Old Nov 27, 2009 | 10:30 PM
CruiserClass
OK, last bump. If no one has any ideas I'll just figure I've stumped even the mighty collective knowledge of FTE.
Old Nov 27, 2009 | 10:43 PM
Layson's Avatar
Layson
Could be an IPR issue... can you watch your ICP? You would see the psi spiking up and down... Do you have AE?
Old Nov 28, 2009 | 08:00 AM
CruiserClass
OK, after some searching I figured out what ICP and AE is. Its a late 99. I'm not sure how to check the injector code, nor do I have a way to monitor fuel pressure.
Old Nov 28, 2009 | 08:39 AM
Visseroth's Avatar
Visseroth
Here's another bump. My truck does something simular, specially during idle but you can feel it while driving a steady speed on a flat surface. Mine is also a 6spd
