Hot side cac boots
Old Aug 18, 2019 | 05:42 PM
green_95's Avatar
green_95
Hot side cac boots
So I ordered the upper and lower hot side cac boots from riff raff to replace my old ones, because my lower boot was oil covered. Once I got them off I could not find any visible signs of a crack or hole and the lower boot had rtv glue on it where it connects to the metal tube. I also noticed the old boots had ridges in them so they would match up to the grooves on the metal tube. My new riff raff boots did not have these ridges. I cant help but feel that these are going to leak.
Old Aug 18, 2019 | 06:12 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
No you won't have any issues with them. Just make sure you tighten down the clamps sufficiently. The turbo outlet boot had a rib to the pipe, but we have purposely excluded it from the lower boot for a better fit and there is no loss of retention. If you need anything just let us know.
Old Aug 19, 2019 | 12:54 AM
SmackDaddy's Avatar
SmackDaddy
Install them per instructions and no worries. I have thousands of miles on a full set. CCV reroute will help by getting the oil vapor out of the intake.
Old Aug 19, 2019 | 04:29 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Full set on my truck also. No problems. Make sure everything is spotlessly clean before install (No oil residue).
Old Aug 19, 2019 | 11:30 AM
Striderwv's Avatar
Striderwv
I had the same concern. I emailed RiffRaff because I read conflicting reports on wheather they had internal ridges. I was told ridges were in the boots. Mine only had a ridge for the lower one, the turbo did not. I was disappointed, but given FTE members I trust use them I decided to give their boots a try instead of returning them. Like Rusty says get everything spotlessly clean. I used brake parts cleaner and hairspray (probalbly a plecebo) on all mating surfaces (This has worked well with me even reusing old stock boots). No problems so far.
Old Aug 19, 2019 | 12:13 PM
duck fan's Avatar
duck fan
Because racetruck
I have been using Riffraff boots on my 7.3L and 6.0L over the years and don't have any issues. You will be very happy with the quality I am sure as I have had one set on for almost 8 years with no issues.
cqs2506
Jan 27, 2020 07:41 PM
cscheid
Aug 29, 2018 08:54 PM
allingeneral
Jul 27, 2015 08:16 PM
firestroker8706
Mar 6, 2011 08:14 PM
Tater17
Mar 18, 2007 03:28 PM
