Headliner question - does it tuck "under"?
I have a '79 F350 2WD standard cab. I remove the headliner when I bought the truck because it was gross and had mildew stains. I kept the trim, and cleaned up the trim and clearcoated it, and bought new stainless screws for when I put them back on.
I was thinking of making a DIY headliner, and I can use the trim for the pattern , and just cut the shape about 3/8" less than the trim size.
However, I couldn't remember - how exactly does the headliner stay up? Does it just tuck under the "edge" of the trim, or does it go under the "roof edge" of the ceiling?
I think it just tucks between the trim edge and the ceiling, but can't recall for 100% sure?
The headliner backing is 1/8” Masonite from a hardware store. I cut it about 3/8” shorter than the chrome trim pieces.
Then I picked up some marine grade vinyl from JoAnns Fabrics and a can of 3M Super77 contact adhesive from the Depot.
I cut the vinyl longer than the Masonite, glued it to the Masonite with the 3M Super77 and then trimmed it to the exact size of the Masonite with a utility knife.
Then I installed the new headliner. I didn’t need to use the center ceiling screw because the 1/8” Masonite is plenty strong and rigid with just the perimeter trim installed.
Hope this makes sense. Good luck!
Sounds perfect, I will follow your plans, I was thinking along the same lines, thanks for the tips!
Something like
And another on one just the adhesive, YES it matters. https://autosneed.com/best-headliner-adhesive-reviews/
If you are shopping at JoAnns Fabrics for material you can also get some better adhesive there. (at least better heat and gravity resistance).
X2 on the HD velcro on the center beam to support the area, also remember to put some jute, boom mat, peel and stick, dymamat ect...some sort of sound deadner up there 1st. And yes is only goes under the trim, measure X10 times cut once.
Is there any thing that works on preventing mildew/fungus from growing on the head liner?
Well it was more that it was very badly "water stained" looking, looked gross. And yep this was in Oregon haha.
I think there are probably some sprays you could use to keep things from growing.
Something like this.
I don't mind using the screw in the middle but I think it will be hard to estimate it's position to get the hole in the correct spot
- 3M 38808 Headliner and Fabric Adhesive
- Permatex 27828 Headliner and Carpet Adhesive
- Polymat Hi-Temp 797 Spray Glue Adhesive
- Loctite 37312 Maximum Strength Headliner Adhesive
- 3M Super Yellow Trim Adhesive – 08090
- Gorilla 6314407 Spray Adhesive 11oz, Clear
- 3M Spray Trim Adhesive – 08074
- Heads-Up Quick Fix Headliner Adhesive
- 3M Foam and Fabric 24 Spray Adhesive
- Dap 121 High Strength Spray Adhesive
If you want to mark the hole for a screw you can use nail polish, lipstick, paint, white out, or anything else that smudges easily and press up on the headliner it'll make exactly where the hole needs to go.
You guys that used hardboard are more patient than I am. What a royal pain in the *** to try to get that into position. It's just too heavy and stiff. (1/8" hardboard) . The original headliner was just foam backed cardboard I believe.
I'd rather try using that corrugated plastic board if I can find a large enough sheet.
Plus, all I have for my pattern is the trim. Insane bitch to try and cut accurate with just that. Screw that, just doesn't work worth a damn. Maybe if I make one out of cardboard first.
