A/C question
Old Aug 18, 2019 | 12:45 PM
AZSCAWPION's Avatar
AZSCAWPION
A/C question
I know my a/c is not original, but is from that era. Can anyone tell me what would have been used or what can be added now to kick the idle up when running the a/c. In the past, I've adjusted the idle ever so slightly to compensate. Was wondering what would be more correct.
Tony
Old Aug 18, 2019 | 12:47 PM
User 71024's Avatar
User 71024
The aftermarket companies should have an electric kick up solinoid that you can wire to the compressor feed so when the compressor kicks on it steps the idle up.
Eric
Old Aug 19, 2019 | 05:09 AM
Crop Duster's Avatar
Crop Duster
AC solenoid
Tony
Without typing a book you need something like this.
Ford used a solenoid like this one, wired into the compressor clutch circuit. You will have to find or make a bracket to mount it if your carburetor doesn't have one already.
Old Aug 19, 2019 | 07:39 AM
AZSCAWPION's Avatar
AZSCAWPION
Thanks to both for the info.
So went and dug out the original 2bbl carb that was on my truck when I bought it. Low and behold, there's the bracket. Never gave it any thought. Doh! Looks like the bracket for the holley was there all along too. Now I know what to look for. Thanks for the diagram.
Old Aug 19, 2019 | 01:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original 2100 series 2V would not have had an electric solenoid. It would have had a dashpot (9B549 in pic)...but only with A/T
With M/T .. there was nothing.
Old Aug 19, 2019 | 01:58 PM
AZSCAWPION's Avatar
AZSCAWPION
Well then, just to be clear, the original "to me" carb has the bracket. Interestingly, it also has a dashpot. Not for the A/C though
Old Aug 19, 2019 | 02:15 PM
AZSCAWPION's Avatar
AZSCAWPION
So, something similar to this? This is on my '70 Lincoln MarkIII
What actuates it? Nothing connected to this one.
Old Aug 19, 2019 | 02:28 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The spring holds the plunger outward at a certain distance and when the throttle linkage hits the plunger it takes a couple of seconds for it to depress during which it keeps the butterfly valves slightly open keeping the engine from stalling. The distance is adjusted using the threaded end and lock nut.
Old Aug 19, 2019 | 02:37 PM
AZSCAWPION's Avatar
AZSCAWPION
So the one in my second picture would solve problems with sudden deceleration. For the a/c would it need to be vacuum actuated? Or would only 2 second stoplights allowed? Or readjusted for winter/summer?
Old Aug 19, 2019 | 02:47 PM
TA455HO's Avatar
TA455HO
Lead Gopher
For the A/C system it is usually tied to the compressor clutch engaging. Since the compressor takes some engine power to run it when it is engaged it's not uncommon to have an electrically activated solenoid like in Crop Dusters picture.
Old Aug 19, 2019 | 03:03 PM
66v8baby's Avatar
66v8baby
That's the bracket you need for what you're trying to do. A dashpot isn't going to cut it. Like Chad and crop Duster said, you need to bump up the idle when the A/C is on, so it has to be tied into that circuit.
Old Aug 19, 2019 | 03:04 PM
AZSCAWPION's Avatar
AZSCAWPION
So, similar then to my first picture. One to help with sudden stop/decel, and a separate one for A/C? ND states that original for A/C wouldn't have been electric. Don't see a second one on my Lincoln though. And I believe that carb is original to both me and the car (51,000 miles actual).
Old Aug 19, 2019 | 03:07 PM
AZSCAWPION's Avatar
AZSCAWPION
That's what I'm figgering. Whether original was electric or not, probably what I will go for.
Always looking to learn though.
Old Aug 19, 2019 | 03:23 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I'll let ND interpret but I think what he said was the original 2100 carbs wouldn't have had an electric solenoid. The anti-stall dashpot did come on some trucks that were originally automatic transmissions (A/T). Not A/C. These trucks didn't come with factory A/C, only dealer installed A/C, so the carburetors were not set up for it originally.
Old Aug 19, 2019 | 03:27 PM
NumberDummy
But this is not the original carb because it has a automatic choke. All 1965/66's had a manual choke w/a choke cable.
And, no Lincoln had a 2100 series 2V, all were 4V's.
