Fuel pump wiring
Old Aug 17, 2019 | 12:39 PM
disturbinglee's Avatar
disturbinglee
Trailering
Fuel pump wiring
Hi everyone, I noticed my front sending unit only has the yellow/white wire connected.. any thoughts on this?
Old Aug 18, 2019 | 05:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
that is because your truck does not have an in tank pump. it only has a sending unit, so it only needs one wire hooked up to work.
is that wire soldered to the terminal? it looks like it.
the sending unit probably died or the pickup broke off and someone replaced it with a gas engine sending unit.
Old Aug 19, 2019 | 05:52 PM
disturbinglee
Trailering
Yes it is soldered on. Also, is there any way for me to tell if the switch between my front and rear tank is working? When I switch it my fuel gauge just goes up more full.. and when I switch back it goes up again, and again ....
Old Aug 20, 2019 | 04:20 AM
tjc transport
i ain't rite
if one tank sender was bad and needed to be replaced, there is a good bet the other sender s bad too.
only way to test the switch is to run it on that tank for a while after filling the tank up, and seeing if it used any fuel out of that tank.
Old Aug 20, 2019 | 09:02 AM
knottyrope's Avatar
knottyrope
can run air from the hard lines running to pump and bowl and listen to the tanks for air
Old Aug 20, 2019 | 09:32 AM
disturbinglee
Trailering
Neither sending unit is bad, I was able to add fuel and see that the fuel level went down. Also, not sure what your man by put air through hard lines?
Old Aug 20, 2019 | 09:54 AM
farmert's Avatar
farmert
If you added fuel and the float showed the level went down, then someone put a sending unit in from an old 6.9-7.3 IDI in your truck, as they read the ohms/ resistance different than these trucks. I don’t remember which is which, but one reads more resistance as the level rises, and one reads less.
Old Aug 20, 2019 | 09:56 AM
disturbinglee
Trailering
No my gauge went up, and kept rising each time I would swtich between tanks. I can tell the level went down by looking into the physical tank
Old Aug 20, 2019 | 01:55 PM
knottyrope's Avatar
knottyrope
forgot to quote it
Old Aug 20, 2019 | 02:03 PM
disturbinglee
Trailering
Originally Posted by knottyrope
forgot to quote it
Ah, understood.
Kleenax
31
Oct 5, 2013 09:14 PM
danyl01967
Jul 26, 2011 09:39 PM
skookum
Aug 2, 2010 09:34 PM
wess466
1978 - 1996 Big Bronco
Dec 7, 2005 04:03 PM
