Jimmy Jammers - The down side
Old Aug 16, 2019 | 08:21 PM
Chrislorl6211's Avatar
Chrislorl6211
So a while back I installed Jimmy Jammers on all my doors. I replaced the drivers door lock with the Jimmy Jammers kit and all went well.
Yesterday for some reason after being parked at the airport for a week my battery was dead. Guess what... No door lock, I can't get in my truck to open the hood.
I ended up calling AAA to get a lockout service and a jump start.
To make sure this never happens again I am installing a jump start port like you see on tow trucks. If it happens again I can plug in the cables, attach them to a battery or other vehicle and power up the truck so I can get inside.
Just sharing an experience so someone else doesn't have too.
Old Aug 16, 2019 | 08:47 PM
wb6anp's Avatar
wb6anp
Been thinking of doing the same thing, Just not sure how yet
Old Aug 16, 2019 | 08:49 PM
Chrislorl6211
Here is the kit I am using.
Jump start outlet kit Jump start outlet kit
Old Aug 16, 2019 | 08:51 PM
wb6anp's Avatar
wb6anp
Thanks that what I was trying to find
Old Aug 16, 2019 | 11:03 PM
mhoefer's Avatar
mhoefer
Or you could take your key out of your fob and unlock the drivers door and pop the hood? Did you remove the lock from the drivers door when adding thejammer?
Old Aug 16, 2019 | 11:19 PM
wb6anp's Avatar
wb6anp
Both of us did yes. Tah is a weak point on these trucks, They grab the lock cylinder with channel locks and twist it to unlock the door.
Old Aug 17, 2019 | 02:38 AM
rewillia's Avatar
rewillia
Thanks for sharing. Might we ask how AAA was able to gain entry or jump power to the truck while there at the airport parking lot?
The quick connect jumper cables as referred to above seem to be a logical solution provided one has accessible storage to the cable/clamp section outside of the cab if and when needed. That stated, I suppose one could tie-wrap them securely onto the chassis/frame somewhere underneath the truck if desired. Will need to look into this myself as I too have the lock cyl, removed and jammer plates in my doors.(after previous theft attempt)
Maybe something like these, mounted in an inconspicuous location under the front bumper in inside a front wheel-well
https://www.amazon.com/Fastronix-Premium-Remote-Battery-Charging/dp/B00YFFMS6A/ref=pd_lpo_sbs_263_t_1?_encoding=UTF8&psc=1&refRID=GMCH5QBZZ1TS6TX357TA https://www.amazon.com/Fastronix-Premium-Remote-Battery-Charging/dp/B00YFFMS6A/ref=pd_lpo_sbs_263_t_1?_encoding=UTF8&psc=1&refRID=GMCH5QBZZ1TS6TX357TA
https://www.summitracing.com/parts/q...stionsanswers/
Again, thanks for sharing....will be interesting to see what others here in the FTE forum have done in terms of being able to jump power to primary battery or to the starter motor, etc.
Old Aug 17, 2019 | 04:14 AM
Mattwolffelectric's Avatar
Mattwolffelectric
Another thing to think of the downside of removing lock cylinder, is if lock motor goes like it did in my 14 , never get in without breaking a window. Only reason been so hesitant to do that mod
Old Aug 17, 2019 | 04:37 AM
rewillia's Avatar
rewillia
Hell, if that ever happens I'll just have to find another thief like the one that broke into my truck the first time and ask him to bring his hammer. Bottom line is FORD needs to come forward with a better solution in terms of its door lock and handle design but of course that does little to nothing for us current model owners. The fact that anyone with channel locks can get into one of these trucks in <2 mins. says a lot in terms of the prevailing cylinder lock design.
Old Aug 17, 2019 | 05:13 AM
Chrislorl6211
As I stated "I replaced the drivers door lock with the Jimmy Jammers kit and all went well."
That is the whole idea with Jimmy Jammers kit. You remove the lock cylinder as it is they easiest way to break into your truck and the #1 way it is done.
Old Aug 17, 2019 | 05:21 AM
rewillia's Avatar
rewillia
Chris,
As previously asked (above), once you encountered the loss of power and called AAA, how did they manage to get you going?
Old Aug 17, 2019 | 05:22 AM
Chrislorl6211
He was able to insert a balloon between the back door and chassis at the top corner. By inflating the balloon it pulled the door frame out enough to reach in with a long tool. The tool had a noose at the end, it went around the lock **** on the door. By pulling back on the cable it tightened around the lock **** and he pulled it up.
I can keep mine in my bed under the cover. But keep in mind I could not unlock the tailgate either as there is no key lock back there too. The only key lock is in the door and we removed that.
https://www.amazon.com/Fastronix-Pre...BZZ1TS6TX357TA
Those are good ideas. Make sure you have a ground nearby too.
I have thought about getting a small jump started pack to through in my bed box as well...
No idea what drained the battery, it is 2 years old and has been a hot summer, nothing aftermarket draining the battery, so I replaced the battery already.
I know it would be under warranty but I just do not have time to make an appointment and travel to the dealer in the next few weeks and can't be without the truck.
Old Aug 17, 2019 | 05:23 AM
Chrislorl6211
Chris,
I ended up calling AAA to get a lockout service and a jump start. They opened the vehicle (see previous post) then I opened the hood and we jumped it.
Old Aug 17, 2019 | 08:21 AM
whirledpeaz's Avatar
whirledpeaz
Hopefully they didn't damage anything in doing that. Got locked out of an altima once. They basically pried the door open at the top to reach the lock. Warped the door. I'll break the glass before I ever do that again.
Old Aug 17, 2019 | 08:46 AM
6.2caribou's Avatar
6.2caribou
FWIW...anyone with a Boss snow plow, or similar type where the plow pump sits on the removable plow frame, will have an externally accessible battery connection point.
Edit: the battery connection will likely pass thru a relay, so you'd have to run an external control wire too.
