1995 E150 - Code 452 “Open speed sensor circuit” diagnosis help (PSOM?)
Old Sep 11, 2019 | 06:55 AM
  #91
subford's Avatar
subford
It is starting to look like you have a bad PCM.
Old Sep 11, 2019 | 01:36 PM
  #92
Zacto's Avatar
Zacto
IT'S FIXED!
Pretty sure it was the PSOM after all...
While tracing the wiring harness to the 4WABS under the van I gave the OSS sensor connector a little wiggle just to check on it and it wasn't plugged in all the way! Plugged it in and went for a test drive and it shifts fine! No OD off light flashing and cruise control works! I definitely feel like an idiot, I must not have locked the connector all the way down and it probably came disconnected on the first test drive after replacing the PSOM. That explains why the tranny and OD off light behavior was different after replacing the PSOM, because the PCM wasn't getting any reading from the OSS at all...
THANKS SO MUCH SUBFORD! Sorry that after all you walked me through it ended up being something so dumb but now I know way more about the van than I thought I ever would. I definitely owe you one. Maybe I'll drive the van up to Kansas to deliver you a 6 pack haha.
ABS light still comes on intermittently but I'll worry about that later.
Now I just need to transfer odometer data from old PSOM to new. Do I need a specific EEPROM programmer? Or will any work? What sort of software do I need?
Old Sep 11, 2019 | 02:25 PM
  #93
subford's Avatar
subford
I can not say for sure but would think any EEPROM programmer would work.
I bough one off amazon and it came with software.
I just had to buy a 8 pin dip clip.
It works with W10, W7 and XP computers.
I think they shipped it from China.
The one I bough:
Amazon Amazon
Amazon Amazon
Old Nov 8, 2019 | 03:29 PM
  #94
Zacto's Avatar
Zacto
Tranny now bumps/shudders into 3rd & OD
@subford Problem with VSS signal seems to be fixed but now after driving the van quite a bit the tranny bumps/shudders when shifting into 3rd & OD. Feels like going over rumble strips when shifting at speed. Could this be happening because I haven't recalibrated the speedometer for my tires? Or should I try a flush and fluid change?
Tom
Feb 11, 2021 10:42 PM
Caddo Kid
1983 - 2012 Ranger & B-Series
Apr 24, 2018 10:45 PM
Tady
Jan 21, 2018 06:02 PM
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
bowmar
May 17, 2005 09:57 AM
