1995 E150 - Code 452 “Open speed sensor circuit” diagnosis help (PSOM?)
Finally got my hands on a legit service manual. Manual says to check the PCM first. What am I looking for on the PCM? Corrosion? Damaged pins? Anything else?
Is the PCM part of the speed sensor circuit? I thought the PCM just received an input from the PSOM?
Seems any further diagnoses will be difficult without a breakout box. I may just go ahead and send off the instrument cluster for an overhaul and hope that solves the problem.
How many miles do you do you have on this thing?
can you find the terminal breakdown for the plugs on the back of the PSOM? Namely the VSS circuit?
Found the appropriate wiring diagram in the manual so now I can just trace the wires by color to the plug terminals! Will test after work (also picking up a new multimeter on the way home.)
I am definitely not an electrician... What exactly am I testing for and how do I test? One end of the multimeter to a solid ground and the other end to the terminal, checking for resistance of less than 5 ohms right? Anything else?
There is no continuity when testing VSS circuit at the PSOM connector plug. And the VSS circuit within the PSOM itself has continuity.
Resistance in the VSS circuit at the PSOM connector and the ABS data link connector is about 1900 ohms. VSS input and output at PSOM both seem to be grounded.
All speed sensors (rear axle, front wheels and tranny) are getting 1.4V with key on engine off. Haynes manual says it should be getting 10V and if not it's a problem with the PCM. I'm not convinced of that. By the VSS/4WABS diagram below, it doesn't seem the PCM would be part of the "Open speed sensor circuit."
So what's next? Follow the wiring harness around the van looking for damage? Somehow test the 4WABS module and/or PCM?
4WABS Wiring Diagram 1995 E-150
Ah ok, that makes sense. I'm pretty convinced it's not my speedo cluster. The speedo works fine.
I'm going to jack it up and test the speed sensors again... Should there be continuity between the pins of the sensor?
My experience here is installing a brand new 20XX cluster from a diesel fueled van into my 2003 gasoline E250 because the coolant temp gauge wasn't working. The "wrong" cluster had full function of gauges and warning lights but the odo wasn't working and the transmission wouldn't shift normally.
Since your chassis is a 1995 it could be different but as already said the schematic showing here does have the PSOM in the cluster as part of the ABS system.
I tested the resistance in the rear ABS speed sensor at 1900 ohms. Specs in the manual say that sensor should be 1400 ohms. Could the extra resistance be causing a break in the circuit? Could that be why the OD off light doesn't start flashing until about 25mph?
By all means do whatever tests you feel are appropriate before sending the cluster off for repair. A best case scenario would be finding the correct year and fuel type cluster from a scrap yard for cheap and swap it in---that's not a fool proof test but it would maybe give you a better idea what the real problem could be.
A 1992 - 1994 will work but may have some needle jumping.
You should be able to tell if the stuff on the PSOM board is from a leaky cap or not.
Grab two or three PSOMs from a pick and pull yard as they would not cost much and you can use them to test the VSS circuit to the Speed Control and the PCM.
The only thing that points to a bad PSOM is the Speed Control not working but could be a bad Speed Control Module.
You have a 4R70W transmission so it shifts off the OSS (Output Shaft Sensor) on the transmission.
You can unplug the PSOM and the transmission will still shift just fine.
You may also have problems with the ABS but it would not effect the Speed Control or the PSOM unless it was pulling the VSS signal train down but I dough that if the Speedometer is working OK.
So you're saying the PSOM has nothing to do with how the transmission shifts? The OSS isn't part of the speed sensor circuit? I'm a bit confused by your reply. Would driving with the PSOM unplugged be a way to test if it is indeed the PSOM?
I am having problems with the ABS light coming on... Could the fact that the replacement ABS/VSS in the rear axle has more resistance than the oem sensor be causing the intermittent ABS light?
From what you're saying it seems like there could be multiple issues... I assumed all the components I am having problems with (ABS, speed control, transmission) were all part of the same speed sensor circuit that is open and throwing the code...
The OSS is a direct input to the PCM. It is not part of the PSOM, Speed Control or 4 Wheel ABS circuit.
My PSOM quit and was out for a week but my 4R70W transmission still shifted OK. This is what I am going by and I do not know the program inside the PCM.
This image is for a truck but yours operates about the same.
Attachment 277289
You might try unplugging the speed control module and see what happens.
Worked up the courage to take the speedo cluster apart and discovered damage on the PSOM circuit board. Looks like what I thought was leaked electrolyte was actually a blown component. You can see the burnt component in the first image below. Also, it looks like there is some heavy build up on the capacitor there too. On the other side of the board, there seems to be some damage that could be severing the trace but I'm not sure - check out the second photo.
I also noticed an issue with the warning light connector on the back of the cluster that may be causing my ABS light to come on. Looks like some copper melted, bridging two of the connection points. Traced the circuit and one of them looks like it goes to the ABS light. This may explain why the ABS light comes on so randomly. You can see what I'm talking about in the last image below.
So looks like I will be sending the cluster off for an overhaul. Any recommendations for shops specializing in instrument cluster repair?
PSOM pcb damage
Damaged traces on PSOM pcb
Warning lamp connector damage
