Disabling hyper flash with LED rear turns
Old Aug 13, 2019 | 06:55 PM
vavtx's Avatar
vavtx
Has anyone figured out how to do this?i tried Forscan but it still had the hyper flash. I have searched and searched the forum but no joy. I did not want to install the resistors but I guess that may be the only alternative. Can anyone assist?
2017 F350 CCLB 6.2
Old Aug 13, 2019 | 07:32 PM
honda250xtitan's Avatar
honda250xtitan
If you do resistors buy quality ones. and mount them to metal. They get super hot.
Old Aug 13, 2019 | 11:55 PM
Nick-ApolloOptics's Avatar
Nick-ApolloOptics
Former Vendor
Did you do bulbs only or did you do full LED replacements? What brand?
Old Aug 14, 2019 | 05:34 AM
rwilimo's Avatar
rwilimo
You can absolutely do it with Forscan, I did it a long time ago so I don't have the codes handy but they are in the spreadsheet for sure
Old Aug 14, 2019 | 07:24 AM
Dan1954's Avatar
Dan1954
I had this problem when trailers attached to my SD were outfitted with led lights. I have no problem with my 5th wheel equipped with conventional lights but my new boat trailer w/ led & my old utility trailer that I upgraded to led lights experienced the hyper flash & "fault" messages. Other members of this website recommended an adapter that has worked for me. If this sounds like your problem I suggest the Tow-Ready 7-way flat pin to 7-way flat pin LED Lamp-Out Bypass Adapter #20142.
Old Aug 14, 2019 | 08:15 AM
wildcard30's Avatar
wildcard30
UPDATE.
The orange lines in the spreadsheet are what needs to be changed for front and rear LEDs.
This is done using the text based part of Forscan, not the HEX area where you change individual hex codes.
PM me if you want more info.
You did not mention if you installed brake and front turn LEDs. If you did both, there are at least 2 separate changes for them. If I have a chance, I’ll check my Forscan sheet. But they are in there.
Old Aug 14, 2019 | 06:50 PM
vavtx's Avatar
vavtx
Thanks for the responses everyone. To answer a couple of questions.... I replaced the tail light bulbs only and have not hooked up a trailer yet. I will give the changes in Forscan mentioned above a shot and report back.
Thanks again!
Old Aug 14, 2019 | 07:31 PM
wildcard30's Avatar
wildcard30
If it’s just the rear you need the rear led line, the ABM configure line and the DTC operation line.
Old Aug 14, 2019 | 10:40 PM
BillyE's Avatar
BillyE
Change “outage” to “no outage” in three locations in BdyCM (not as-built). Can’t remember the names of the three, but there’s three.
Old Aug 15, 2019 | 06:07 AM
Poncho450's Avatar
Poncho450
Check this video out at the 24:00 mark. That's where the FORScan portion begins.
https://www.youtube.com/watch?v=gDkC...ature=youtu.be
Old Aug 16, 2019 | 05:40 PM
vavtx's Avatar
vavtx
Thanks again everybody. Awesome support! The video was very helpful. It was the “Outage ABM” that needed changed to “No Outage” I was missing. I wonder how that step can get added to the spreadsheet?
Old Aug 16, 2019 | 07:55 PM
wildcard30's Avatar
wildcard30
The ABM configuration is on one of the sheets
I did this mod some time ago and the spreadsheet info I posted cross references back to a F-150 spreadsheet.
Most of the F-150 crosses over to the super duty. But I have a complete master list of the spreadsheet I have found/used to do all my mods. But, I’m all about record keeping when doing software/firmware modifications.
I do this stuff for a living.
Old Oct 10, 2019 | 11:01 AM
wmnmy's Avatar
wmnmy
I hooked up my trailer for the first time to this truck and the trailer tail lights where flashing . All the lights on my trailer are led I will try the 7 pin connector adapter I guess or take it to the dealer .
Old Apr 20, 2024 | 10:19 PM
Summers22's Avatar
Summers22
@Poncho450 what module is "outage ABM" in?
Old Apr 21, 2024 | 06:00 AM
Poncho450's Avatar
Poncho450
It's been a while but I believe it's the body control module, shown a Bdy or BCM.
potato potato
Oct 10, 2019 11:15 AM
Kelly MT
6.7L Power Stroke Diesel
Feb 27, 2018 10:02 PM
nomadx4
Dec 10, 2012 03:27 PM
signut
Feb 8, 2004 09:52 PM
