Dana 60 hubs
Old Aug 13, 2019 | 08:39 AM
66dually's Avatar
66dually
Dana 60 hubs
I’m trying to figure out where to look or what to look for on my 66 250 camper special for a replacement hub, it’s the Dana 60 and I have 2 studs that are stripped out from what holds the axle on. Sorry if that’s not correct terminology. I was wondering if there is another source for the hubs I cannot find them myself and am seeking other sources. I was simply checking the brakes and ran into this proble. Any ideas where to look? Is there another hub from a different model that will fit?
Old Aug 13, 2019 | 10:07 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Hi and Welcome. There are two different types of hubs possible on a 1966 F250. There is the hub that is pressed together with the brake drum so it comes off as one unit and then there is the other type where the brake drum comes off separate from the hub. The part number is different for each type. Which type do you have? Figuring that out is the first thing I would do so you can make sure you get the right part.
Old Aug 13, 2019 | 11:12 AM
Christmas's Avatar
Christmas
Why not Heli-coil it?
Old Aug 13, 2019 | 11:57 AM
Cheddar's Avatar
Cheddar
I agree with Christmas those bolts are there for rotational sheer strength as they are what takes the load when the axle turns, driving the hub. There is little force required to hold the axle in, they would be just as effective helicoiled.
Old Aug 13, 2019 | 12:30 PM
66dually's Avatar
66dually
I have thought about doing that but was not sure if it was a viable option so I will probably just do that, and also it is the presses on drum where I have to take axle out, I was calling it a full float
Old Aug 13, 2019 | 12:44 PM
Christmas's Avatar
Christmas
Axle will come right out. Make sure to get new gasket. Use locktite red on Helicoil only. You will spend more time at the store than it takes to do it.
Old Aug 13, 2019 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1966 F250 Camper Specials & F250's with a 7500 lbs. GVWR have 12" x 2 1/2" rear brakes, use a different hub than F250's with 12 1/8" x 2" rear brakes.
C6TZ-1109-A .. Rear Hub - Use with 12" x 2 1/2" rear brakes / Obsolete
1966/68 F250 // 1969 F250 before serial number F30,001.
No Ford dealer or obsolete parts vendor has any, none on ebay.
B7TZ-1151-B .. Stud - Retains Axle Shaft to Hub / 7/16" -14 & 7/16" -20 x 2.00" long / Obsolete
NOS PARTS LTD in Waxahachie TX has 10 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 46 = 800-543-4959.
See 1104 hub and 1151 stud in pic.
Old Aug 13, 2019 | 08:39 PM
66dually's Avatar
66dually
Thanks for the information, when I get some time this weekend I’m going to go the route of helicoil and go from there
SSBMX
Jun 24, 2016 02:58 PM
belshe92
Apr 13, 2016 01:32 AM
79Ford4x4
Feb 23, 2010 09:28 PM
relentlessmx
Jan 1, 2009 12:00 PM
Meaty-BTZ
May 9, 2000 08:37 PM
