But the forum is still relevant for the truck, shouldn't the 6.7 talk just fall under the 6.7 forum?
Agreed, the forum would be relevant for the body and suspension. But, all of the Powertrain questions (except the 6.2l) may become confusing since the powertrains will share absolutely nothing.
Since they will be different than the 17-19, should they have their own thread?
The only thing that is different is tailgate emblem is small and the transmission and front grill and headlights the foglight. Otherwise all parts the same or made cheaper more plastic or you might think that is fantastic.
I would like to see a 2020 drive train forum.
It’s not a light refresh, but rather the diesel engine will sport entirely new internal components, a new turbo, fuel injectors and entire new fuel system, along with a brand new transmission. The basic truck itself is the same, but the drivetrain will share absolutely nothing with the 2017-2019.
The same thing goes for the new 7.3L engine.
the only thing the diesel gets is a light refresh and 10sp
the 6.2 get replaced with a 7.3 but when in the year is ?
otherwise all part numbers are the same
There's already engine-specific sub-forums if you want to keep things clearer. They don't get the traffic of this sub-forum, but that's because this sub-forum covers a wide variety of trucks. You kind of have to pick your poison on that issue.
Like it says here
After talking with our contact at Ford here is what we at SPE can tell you. Please be advised, this is only speculation from a reliable source.
Got my info from a ford engineer it will bump up the power but the long block is still the same
Like it says here
The info about the actual changes to the 6.7L have been introduced by Ford engineers, and simply summed up in written form from SPE, instead of video form. The structural changes are fact. Take a little time and look at the unveiling videos of the engines and transmissions from Ford engineers..
The only speculation from SPE are the actual power numbers. Their estimates may actually be very modest.
I would imagine the current 6.7L is at the end of the line in capability, and the 2020 6.7l with all of the structural improvements along with the revamped fuel/head/turbo redesign may lead to additional 100lbs of torque improvement for later power bumps.
Like it says here
Long block is not the same. They went from aluminum pistons to steel pistons...which means the rods probably changed too. I can't find the YouTube video I watched a couple weeks ago of it though...
When u find it let me know LOL Maybe its the 7.3 gas u are talking about
No point going into it. I’m sure Ford’s advertising campaign will be starting very soon and explain everything. The SPE link sums it all up.
[QUOTE=George C;18798674]No point going into it. I’m sure Ford’s advertising campaign will be starting very soon and explain everything. The SPE link sums it all up.[/QUOTE
There is nothing different by looking at it. I saw the one in person LOL
i hope they did change back to a o ring style gasket for upper oil pan and stop using cheaper parts
