Adaptive cruise/ACC - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Adaptive cruise/ACC
Old 05-03-2018, 08:17 AM
orion1968
orion1968 is offline
orion1968 is gaining momentum as a positive member of FTE.orion1968 is gaining momentum as a positive member of FTE.
Adaptive cruise/ACC
I have ordered all of the parts to do this upgrade and was curious where everyone found the location for the parts to be installed. Most are pretty self explanatory. Does the bumper have to be removed and if so how? I guess that is the main thing I am concerned with. The 3 nuts and deflector are on back-order till the end of the month so I have some time to plan.
Thanks
Old 05-03-2018, 09:30 AM
psdxohio
psdxohio is offline
psdxohio is starting off with a positive reputation.
Thanks
Can you list part numbers and approximate total cost?
Old 05-03-2018, 09:37 AM
jrwinger's Avatar
jrwinger
jrwinger is online now
jrwinger is starting off with a positive reputation.
+1 following
Old 05-03-2018, 10:34 AM
orion1968
Here is the list from Brandon12686 in the forscan thread
Required Parts List
Distance Sensor
HC3Z-9E731-A
Bracket to bumper nut plate
W520822-S441 (X2)
Bracket to bumper bolt
9L3Z-19S426-A (X2)
Distance Sensor Bracket
HC3Z-14C022-B
Sensor Stud Nuts
W520201-S440 (X3)
Sensor Stud
W717467-S439 (X2)
Sensor Alignment Stud
W717468-S439
HUD Display
FL3Z-19G468-A
HUD Display Trim
FL3Z-15043C54-BA
ACC Steering Wheel Switch
FL3Z-9C888-BA
Distance Sensor Bumper Harness
HC3Z-15K867-A
Tow Hook Bolt Cover
HC3Z-17A900-A
13
Tow Hook Surround
HC3Z-8311-G
Air Deflector (modifed for ACC harness)
HC3Z-8327-R
** The old can be cut to accommodate the bumper harness, but this the actual OEM part
Modules That Need Updated
SECM
7C5-01-02
xxx1
xxxx
xxxx
7C5-02-01
xxx2
xxxx
SCCM
724-01-01
xxxD
xxxx
xx
724-02-01
xxx2
xxxx
xx
IPC
720-01-01
2Fxx
xxxx
xxxx
720-01-02
xxxx
7xxx
720-04-01
Exxx
xxxx
xxxx
BCM
726-13-01
xxxC
4xxx
xxxx
ABS
760-03-01
7xxx
xx
CCM
764-01-01
0918
0101
0292
764-01-02
016F
764-02-01
++xx
** All "+" should duplicate the ABS VIN HEX values. (See Below for Ref.) Also, the CCM will need calibrated after all values are entered to activate the ACC
764-02-02
++xx
764-02-03
++xx
764-02-04
xx
*** CCM Should Match These Values (do not modify any of these - ref only)
ABS
760-01-01
++xx
**Duplicate the "+" in 764-02-01. Do not copy the xx (check sum) values
760-01-02
++xx
**Duplicate the "+" in 764-02-02. Do not copy the xx (check sum) values
760-01-03
++xx
**Duplicate the "+" in 764-02-03. Do not copy the xx (check sum) values
760-01-04
xx
**Duplicate the "+" in 764-02-04. Do not copy the xx (check sum) values
Old 05-03-2018, 10:43 AM
wicked 2018
wicked 2018 is offline
wicked 2018 is starting off with a positive reputation.
Orion1968 - very nice documentation on this. I have ACC, but many will thank you for this. Rep added.
Old 05-30-2018, 04:56 AM
orion1968
I got everything installed and programmed like above. Ran the CCM calibration but am having an issue. It turns on fine but the first time it has to auto brake it disables the auto feature. Also not included in the above instructions is that once you have everything setup, you need to go into the settings menu on the dash an enable the auto feature. I have the Diesel and I believe the others who have reported success many have different code for some of the line items.
Old 05-30-2018, 04:01 PM
_huck
_huck is offline
_huck is starting off with a positive reputation.
I'm in exactly the same spot as you...installed last week, I've checked my Forscan values three times and they all match...Hopefully someone knows!
Old 05-30-2018, 04:22 PM
orion1968
Do you have the Diesel?
Old 05-30-2018, 04:42 PM
_huck
_huck is offline
Yup! Seems to be very similar to the problem a couple others were having...not sure if it's related to the SECM or ABS interaction.
Thinking Brandon12686 holds the answer..
Old 06-07-2018, 12:27 AM
orion1968
So based on another posted solution I tried the following.
1. SCCM 724-02-01 xxx2 xxxx - A 2017 F350 Plantinum that has ACC has a 4 in that spot instead of a 2
2. IPC 720-01-02 xxxx 7x - 7 specifies a Flex Fuel vehicle, where i have a Diesel which should be a 5
Before the changes I get
Code: U0401 - Invalid Data Received From ECM/PCM
Additional Fault Symptom:
- Signal Invalid
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Cruise-Control Module
Freeze Frame :
-GLOBTIM: 42430824 sec - Global real time
-IFC_D703: 32768 - Internal Module Fail Code
With both changes I get a 2nd code. But returning the SCCM to 2 I only get the above DTC after it tries to apply the brake.
Old 06-08-2018, 06:43 PM
Roly Poly
Roly Poly is offline
Roly Poly is starting off with a positive reputation.
- Signal Invalid
Status:
Freeze Frame :
FYI , Did the same upgrade, added ACC resulted in the same errors. Reviewed different trucks windows stickers to find the trucks that matched the features I have + ACC. Downloaded the identified VIN's as-built data for each truck. Ran the as-built through the as-built compare utility. The two changes you identified above appear to be correct for 6.7L plus one more your missing
CCM
764-01-01
0918
0101
0292
Should be: (9 should be an A)
0A18
0101
0292
Have not tested yet, left my laptop at work, so I'll setup on another and test shortly. Let me know if you bet me too it...
Roly
Old 06-08-2018, 09:26 PM
Roly Poly
Made the change, still get the 401 code, but only one code. However now there is little car icon with brake lights that appears in the ACC area on the dash just above where the gray bars used to represent the spacing for ACC.
I'll review byte by byte when I get a chance to see if there is anything else.
1. Does any know the torque for the lock nuts used to hold the ACC module?
2. Also does anyone have the vertical alignment procedure, I set the sensor to level.
3. Part number for the cover for the sensor?
Roly
Old 06-08-2018, 11:50 PM
Roly Poly
Found another change that is missing, every truck with ACC has this set in it's as-built. However still have the 401 error, will keep looking.
BCM
726-13-01
410C
4045
00xx
-or-
4xxC
4xxx
xxxx
Roly
Old 06-09-2018, 12:22 AM
355spider
355spider is offline
355spider is starting off with a positive reputation.
I really wish the adaptive cruise would bring the truck to a complete stop and then start up again. It's useless in stop and go traffic where I really like to use it on my Volvo.
Old 06-09-2018, 04:36 AM
orion1968
Cover part # HC3Z-17E811-A
Did you re-calibrate the CCM after the change? I have the car with brake lights with out your changes but only when I get in the range of the car in front. Depends on how you have the distance setup. I will try these changes when I get home tonight.
BCM
726-13-01
410C
4045
00xx
-or-
4xxC
4xxx
xxxx
Roly
Quick Reply: Adaptive cruise/ACC
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
