Modular V10 (6.8l)
Engine shut down while driving
Old Aug 12, 2019 | 08:17 AM
sm1005aust's Avatar
sm1005aust
Our 2005 Winnebago Sightseer Class A(,It is a Ford F53 6.8 liter V10) has been shutting down while driving, we were able to restart by turning the key in the ignition off and on again (in drive)and it begins to run, but a couple of times it did not. All gauges go to zero when it shuts down. We have changed the fuel filter, fuel pump, crankshaft and camshaft sensors and have had diagnostics done at three places enroute (one ford dealer initially) and we are not getting any problem codes.. I should mention that we had some computer diagnostics done to make the motor more efficient and it started shutting down after that. We have gone up to 650 miles without a shut down and other time it is one after another i.e. 20 miles, 50 miles. It is a fairly dangerous situation so any insight would be appreciated.
Old Aug 13, 2019 | 07:20 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Explain how "computer diagnostics" makes the motor more efficient? Was it tuned?
I'm moving this to the V10 forum - lots more people there that are familiar with the V10 and the F-series platform.
Old Aug 13, 2019 | 09:54 AM
johnfist's Avatar
johnfist
If all your gauges are dropping out then it's probably an electrical issue of some sort I'd imagine. Check the alt and battery, also go into more detail about the "computer diagnostics" and who did them.
Disclaimer: I'm not an expert, just a DIYer.
Old Aug 13, 2019 | 10:46 AM
sm1005aust's Avatar
sm1005aust
Computer Diagnostics description
Sorry I misspoke it's not computer Diagnostics we initially brought it into a mechanic to have the cruise control fixed as it wasn't working at the same time we had the mechanic connect an SCT computer to change fuel ratios to get us better gas mileage. After that we had the shutdown problem. Then we had the computer set back to factory setting and we did all of the changes mentioned in the original thread fuel filter fuel pump Etc We also to put in a new Servo and a new valve on the master cylinder to try to fix the cruise control and have also had all the sensors checked and electrical connections and they were deemed to be ok.
Old Aug 13, 2019 | 11:22 AM
johnfist's Avatar
johnfist
Again, I'm not an expert, but if you had fuel problems I think you'd experience other issues, not just an immediate all-stop. Did anyone check out your ignition switch as well? From the sound of it, it sounds more like it's being turned off than something failing mechanically. That's why I thought electrical. Is there any theft prevention on the vehicle?
Old Aug 13, 2019 | 06:52 PM
sm1005aust's Avatar
sm1005aust
We were told that the ignition switch was checked out and it was fine we are unaware of any Theft Protection on the vehicle
Old Aug 13, 2019 | 09:34 PM
super 6.8's Avatar
super 6.8
What is the condition of your battery cables? And not just the terminal ends, but the entire cable assemblies?
Old Aug 15, 2019 | 11:46 AM
sm1005aust's Avatar
sm1005aust
Sorry for the delay, the vehicle is still at the mechanics checking everything out. Don't know if anything has been ruled out yet. However we had checked the battery and cables, to my knowledge.
Old Aug 16, 2019 | 10:11 PM
maticuno's Avatar
maticuno
I had very similar symptoms in my 2003 F-250. It ended up being the previous owner damaged the ECM when he installed a performance chip. A junkyard ECM fixed the problem and I've been trouble free now for over a year. The diagnostic trick I used to determine a bad ECM was keeping a code reader in the truck with me. When the engine shut down, I safely pulled to the side of the road, leaving the ignition on and plugged the reader into the OBDII port. The code reader could not communicate with the ECM. When I turned the ignition off and back on again, the code reader connected and showed no errors and the engine fired and ran fine again. That told me that the ECM had an internal issue that was reset after cycling the ignition.
LIKENIT
Dec 30, 2012 10:01 AM
LFITHEN
Jul 30, 2007 11:45 AM
hatcityhosehaulr
Aug 17, 2006 06:59 AM
Shmokie2
Modular V10 (6.8l)
Nov 2, 2004 07:26 PM
95f1504x4
Oct 8, 2002 09:25 PM
