Compression Test Help Needed Please
Old Aug 10, 2019 | 08:23 AM
croy772's Avatar
croy772
Hi Everyone, I'm back again.
First i want to thank everyone for all the help i have received. My new issue i am working on is severe oil burning. I have heard lots of things to do but wanted to get some opinions here before i do anything. The only thing i knew to do was perform a compression test. Here are the results:
1 - 85PSI
2 - 85PSI
3 - 85PSI
4 - 90
5 - 90
6 - 95
7 - 100
8 - 87
There is oil blowing out through the breather and into the air cleaner. The engine starts first try every time and actually runs rather smoothly. I am just not sure what to do next. Any recommendations? Thanks in advance!!!
Old Aug 10, 2019 | 08:30 AM
timbersteel's Avatar
timbersteel
We're those numbers with a cold engine?
Did you have the throttle plates open when doing the test? Those numbers really seem low.
Old Aug 10, 2019 | 08:36 AM
croy772's Avatar
croy772
I warmed the engine up for 15 minutes but the throttle plate was closed. This was the first time i did it and used a procedure i found which told me to warm for 15 minutes then remove one plug at a time and cold crank the engine. i did diable the coil and the fuel pump. Did i do this wrong and what it correct method? Thanks
Old Aug 10, 2019 | 08:42 AM
timbersteel
The throttle plates need to be in the wide open position. And the engine warm helps narrow down problems.
You can also add a little oil to each cylinder as you Do it to help with the results. Dry and with oil are 2 different results and pinpoint problems.
Old Aug 10, 2019 | 09:38 AM
Tedster9's Avatar
Tedster9
Have to remove all the spark plugs first. Where did you get those compression test instructions??
Block open throttle all the way and open choke. Then perform the test. Engine should be fully warmed up, but this is widely ignored because removing plugs on a hot engine isn't fun. If good, consistent numbers across all cylinders are found with engine cold then it's probably more than a "good enough" test.
Battery must be fully charged and in good condition. I think you'll like the compression numbers a lot better after performing this operation correctly. A mechanic's vacuum gauge can really do quite a bit of engine health diagnosis too. It doesn't replace a compression test exactly, though it's close and a lot less hassle to setup.
Old Aug 10, 2019 | 09:45 AM
timbersteel
As Tedster9 said.
Old Aug 10, 2019 | 06:31 PM
croy772's Avatar
croy772
ok thank you for the insight. i am going to do this tomorrow. i will let you know how it goes. What kind of compression numbers should i be looking for?
Old Aug 11, 2019 | 08:50 PM
TobyB's Avatar
TobyB
Even numbers! Gauges vary widely, so my 120 psi might be your 150.
I suspect you'll be ok- figuring that your crank speed was low with the plugs in,
you should see all of them go up 30- 40 psi. Which is fine.
hth
t
