C6 Torque Converter leaking back over time
Old Aug 9, 2019 | 12:31 PM
teched's Avatar
teched
Hi Guys...Been a while. Been doing some research and have found some info on C6's leaking back into the trans from the torque converter causing fluid to run out any orifice it can find. My 63 Galaxie has a 390 and C6(Yes a C6 not original trans). I was not able to get around to shortening up the shift linkage so when I parked it (For several months) it was not in Park but in was Neutral. Found a brief comment in a post that if the tranny is left in neutral it could leak back. I was going to put a leak back valve in the tranny cooler line, but before I do just wanted to check with you guys about the Neutral thing. Now I have adjusted the linkage and have car running well and the brakes working. I plan on filling it up with fluid again and running it this weekend. Just don't want to come and find a gallon of tranny fluid on the floor.
Old Aug 9, 2019 | 12:39 PM
ford390gashog's Avatar
ford390gashog
The torque converter check valve is in the valve body. If its draining back it's a valve body issue and if its leaking the whole transmission should be gone through. I assume this isn't a new rebuild? Neutral and park are the same position but neutral doesn't engage the parking pawl.
Old Aug 9, 2019 | 02:18 PM
teched's Avatar
teched
Nope, I never rebuilt it. Probably could use a one though. Thanks for the info.
Old Aug 9, 2019 | 05:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It makes no difference on leak back if the trans is in park or neutral.
Old Aug 9, 2019 | 07:32 PM
85e150's Avatar
85e150
Moved, this is a transmission thread.
Old Aug 9, 2019 | 08:39 PM
teched's Avatar
teched
Thank you for moving
Old Aug 9, 2019 | 08:43 PM
teched's Avatar
teched
Do you know if the valve that you can add to the tranny cooler line will fix the blead back problem without tearing the tranny apart.
Old Aug 9, 2019 | 10:12 PM
Mark Kovalsky
That won't have any effect. It's leaking back through the trans, not the cooler.
Old Aug 9, 2019 | 10:36 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
what is it just a check ball that sits on the separator plate... it's probably missing ... or is it actually a Ball and spring.... been long time since I went thru a C6
Old Aug 10, 2019 | 06:20 AM
teched's Avatar
teched
Thanks I guess ill have tear into it
Old Aug 10, 2019 | 12:05 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
TBH the converter leaking back into the tranny can only empty Half of the converter and I wouldn't think that should cause it to puke fluid all over the floor unless other seals are bad and leaking
Old Aug 10, 2019 | 05:47 PM
teched's Avatar
teched
I replaced the pump and front seal. I also replaced the rear tail shaft seal. I replaced a filter and filter gasket. It looks to leak out the shifter arm hole. I added 4 quarts today and it brought it right up to the full mark hot. I have heard that its a common problem with the early C6's. Thanks for the thought.
