Sponsored by: Real Truck
A/C fan speed is not consistent
Old Aug 7, 2019 | 08:00 PM
Rob89's Avatar
Rob89
Hey guys. Truck is a 2016 F-250 Lariat CCSB 6.2 4x4. Had my A/C on today like any other summer day and I noticed the fan speed was inconsistent at the lower speeds. It would speed up and slow down all on its own. If I set it to blow at full speed or one setting below full speed the problem went away however any speed setting below that and the fan would alternate the speed all by itself.
Any ideas?
Old Aug 9, 2019 | 08:28 AM
alloro's Avatar
alloro
Hmm strange, perhaps it's being affected by the heat?
Old Aug 9, 2019 | 09:07 AM
Just Strokin's Avatar
Just Strokin
When the HVAC is in the Auto mode, the speed can vary. I think there are other times the speed can increase or decrease depending on the OAT. The fan speed is controlled by an FET controller located on the bak side of the HVAC box. The dash would need to be removed to change it.
Old Aug 9, 2019 | 09:45 AM
Rob89's Avatar
Rob89
I don’t keep it on auto. I’m glad to hear that it can change fan speeds on its own however it’s weird that I’ve had the truck 3 years (almost to the day!) and Wednesday was the first time it’s done this.
Could I be developing a vacuum leak?
Old Aug 24, 2019 | 06:41 PM
Rob steingraber's Avatar
Rob steingraber
Fan. Speed variates.
Any ideas?
Yes. Had the same issue. $60 and 2 bolts. Motor and fan combo. Under the hood on passenger side. Took me 10 minutes. Now fan works perfect
Old Aug 24, 2019 | 06:50 PM
Just Strokin
I don't believe the fan on the 2011-2016 trucks is under the hood. I think there are 3 screws and can be removed from inside on the passenger side of the HVAC box.
Old Aug 27, 2019 | 01:59 AM
Rob steingraber
[QUOTE=Rob steingraber;18817387]Yes. Had the same issue. I have a 2004 super duty. Different replacement proceedures, but look into your motor and fan. That will definatly cause the same symptoms
Old Aug 31, 2019 | 10:43 PM
JockeyJames's Avatar
JockeyJames
Trailering
If you change your blower motor make sure to replace the blower motor resistor too! I have seen a lot of new blower motors cook from resistors.
