I have a 1977 f250, with front power disk brakes, with the dual piston calibers. I can not find a brake booster for it, i can find one for the single calibers. Is there a replacement or do i have to get one for the single cailbers?
I have a 1977 F250 4WD with front power disk brakes and dual piston calipers. I cannot find a brake booster for it, i can find one for the single calipers (2WD only).
Is there a replacement or do i have to get one for the single calipers? Single piston calipers is different!
D7TZ-2005-B .. P/B Booster - Use with dual piston calipers / Obsolete
1977/78 F250 2WD/4WD // 1979 F250 2WD/4WD before serial number DJ0,001.
I called the local napa, they told me that they can't even order a booster for that truck 🤷*♂️. If I get a chance this weekend I'll see if I can take it off to see if I can find numbers on it
Maybe call a different Napa and see if they can order on the chance your local one looked it up wrong,,even Cardone says currently sold out and Rockauto sold out , could be a hard find to stay original
My local O'Reilly's and Auto Zone had then in stock, I went with the 1st due to having an business account with them and getting a great discount. I got the loaded one with the master cylinder on it. Took it off, bench bleed the m/s, back together, bolt on, a quick bleed and go. More like and like stop now.
