Another DEF/DPF Regen Question
Old Aug 6, 2019 | 12:10 PM
MacMan48's Avatar
MacMan48
I have a 2017 with 13k miles. I never know when the truck is in regen. Is this some "Top Secret" info that Ford Corp. doesn't want the person who paid a metric F*@#ton of money to own their trucks to know about?
I have never seen any indication of a regen or any information on the % of contamination. Is there some "easter egg" you have to hack to find this out?
Just went on a 1700+ mile trip, topped the DEF fluid off before hand came back with the DEF a hair over half full. Seems like a lot to me. Does this seems normal or is it normal?
During this time my milage is gone from 17.2 mpg to 14 mpg running empty, no trailer, no cargo.
Thanks for your input.
Old Aug 6, 2019 | 01:11 PM
HRTKD's Avatar
HRTKD
Forscan can turn on the DPF % remaining screen. The dealer can do this also.
Heavy tires will reduce MPG.
Old Aug 6, 2019 | 01:20 PM
MacMan48's Avatar
MacMan48
Ok thanks I'll ask the dealer.
The tires are the same stockers that came with the truck so it's unlikely they contribute to the degradation in fuel milage since the high milage figure was achieved with them, and their weight and pressure is relatively consistent. But who knows, you might be right. YMMV
Old Aug 6, 2019 | 02:37 PM
HRTKD's Avatar
HRTKD
You said, "running MT" so I assumed you meant "Mud Tire".
Old Aug 6, 2019 | 02:43 PM
MacMan48's Avatar
MacMan48
Oh, no empty=MT but I see where you got that. My bad using unclear shorthand.
Old Aug 6, 2019 | 02:55 PM
Deuce40s's Avatar
Deuce40s
What does MT stand for? Montana?
Old Aug 6, 2019 | 03:28 PM
ddown54's Avatar
ddown54
More resistance on MT if you were towing or loaded down DEF use will go up dramatically good thing it's cheap in the grand scheme of things.
Old Aug 6, 2019 | 03:43 PM
MacMan48's Avatar
MacMan48
MT = Empty by bad.
Old Aug 11, 2019 | 06:19 PM
sluggerbird's Avatar
sluggerbird
How do I get Forscan.I am not going back to the dealership they were going to charge my $55 to plug in my truck just to tell me what my factory keypad number was.
Old Aug 11, 2019 | 08:07 PM
Just Strokin's Avatar
Just Strokin
FORSCAN.ORG
Old Aug 11, 2019 | 09:01 PM
jsukey's Avatar
jsukey
There are also tuners that show when your truck is in regen mode.
Old Aug 12, 2019 | 08:27 AM
rtazz17's Avatar
rtazz17
Edge cts gives you tons of info live. I have my suctioned to my windshield. Youll know most everything you need,engine oil,coolant,egts,def level,soot level,if your in a regen,hp,boost,etc. many more too. Well worth it if you like knowing those things and its stand alone. Not on your phone. Stays in truck. Think it was like 350 or less. Clears codes as well.
Old Aug 12, 2019 | 08:26 PM
Overkill2's Avatar
Overkill2
If you like something smaller, there's the Banks iDash 1.8.
Old Aug 12, 2019 | 08:57 PM
MacMan48's Avatar
MacMan48
How large is the screen?
Old Aug 13, 2019 | 04:43 AM
Just Strokin
CTS/CTS2 is roughly 3" x 5". I have mine mounted in the lower left corner of the windshield. Here is a close up photo of my CTS2...
