So I was putting the pistons on new rods and I accidentally dropped a piston on the concrete floor. Now it’s got just a little dent at the very top of the piston. Is it still usable or is it trash!
You dang sure don't want to pull it apart again just because of a damaged piston. If pieces of that come apart it might damage a cylinder wall the second time around.
I got your p.m. and I will ship a piston out tomorrow.
UPS says Monday delivery. Sorry for the delay in your build but I couldn't bear to see you risk an engine failure due to a damaged piston. These things have a hard enough time staying together because of cracks or broken rings as it is.
