Ford pickup truck body on a medium duty chassis
Welcome to FTE!
Crew or Supercab trucks were available as OEM.
https://www.truckpaper.com/listings/...model/f650-xlt
I'm a little confused as to WHY the OP would want to install an F-250 - F-550 front clip and cab onto an F-650/F-750 truck, which as already mentioned above is not possible. Besides, the cab portion of those trucks is virtually identical to the F-250 - F-550 cabs anyways, save for some very minor small detail stuff (ie larger diameter steering wheel on the medium duty trucks, along with additional bezel trim piece to house the Allison automatic push button shifter on models so equipped etc). What exactly is the intended benefit, (to which I see none)?
Front loader like a tractor, plan is to use high flow hydraulics for the chipper. Please correct me if I am wrong, if a medium duty can serve as a dump truck, crane body and so on I would assume that it wouldn't be unreasonable to have it modified for forestry chippers and front end loaders.
Well, you could adapt the trash truck loader, but you need a flat nose truck for that. A tractor like loader is not practical or useful on the front of a medium truck IMO.
The chipper--if you only need a light duty chipper you could run it off your PTO, but you'd probably be money ahead with a self contained IMO. Tree service, Forest service--all have tow behind or free standing items.
Again, have you seen trucks equipped this way, or do you have a source for this type of equipment?
My local city has a dump truck,I think it's an International, that has a bucket loader on the front. It's arms are more like a trash truck. When it's driven the arms are pulled back along the cab, making it impossible to open the doors. Not that you would when driving, but you have to put the bucket on the ground so you can get out when parked.
It's entirely possible to put a 450/550 cab and front clip on a 650/750 chassis, you'll most likely end up using a 450/550 radiator and intercooler to make it all fit properly.
Other than emissions junk a 6.7 Cummins isn't any bigger than the 5.9 Cummins I have in my F-450, no lift or body mods where made, there's enough room to run a mechanical fan.
As for the loader and hydraulic chipper, neither of those are good ideas, there's no good mounting points to attach a farm style loader and the weight would crush the front springs, the steering components would also be short lived.
A chipper for tree trimming service requires a good amount of power, A transmission or transfer case driven pto providing hydraulic or direct drive power isn't strong enough to handle the power demands of a chipper.
Y2KW57
2017+ Super Duty
91
10-18-2015 09:19 AM
