Stumped need help.
Old Aug 2, 2019 | 05:44 PM
Breathe Together's Avatar
Breathe Together
Possibly an inline fuse?
Old Aug 2, 2019 | 06:02 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Originally Posted by Breathe Together
Did what requested. 12v going all the way thru fuse s but no power to either side of fuse 8.
OK good now we are getting somewhere....from Fuse 'S' it runs thru the Wiring Harness to Connector C202 that is the Big one on the driver's side firewall from there the Black/Orange wire goes to the inside fuse box where it feeds Fuse #8 and also Fuse #16, fuse #4 and Circuit Breaker #12...
BUT your main problem is no power to Fuse #8 so I would inspect that connector C202 .. I'll see IF I have info on that connector (a Pinout)
Old Aug 2, 2019 | 06:07 PM
Breathe Together
Where is fuse 8 grounded? I was always told a ground is usually what burns up.
Old Aug 2, 2019 | 06:15 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ok this is for 93 F series should be same... Pin 70 is the one that comes from Fuse 'S'
Old Aug 2, 2019 | 06:24 PM
Breathe Together
Could I possibly run a jumper wire bypassing c202?
Old Aug 2, 2019 | 06:43 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
that's your Call.... all I can tell ya is that you are loosing 12v between Fuse 'S' and the Fuse Buss that Fuse #8 is on..
it only takes a 10mm deep socket to unscrew the C202 connector and who knows IF you wiggle the harness to it and the one from it going to the inside fuse box .... it might fix itself.
I generally recommend fixing instead of Bypassing
I would also pull Fuse 'S' and make sure the side going out is not fried.. burned or dirty fuse connector.
Old Aug 2, 2019 | 06:52 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you disconnect C202 you can verify if there is 12 volts on pin 70
I use corrosionX on all my connectors to prevent corrosion too
salt environment here in South Texas.
Old Aug 2, 2019 | 06:57 PM
Breathe Together
All pins visually look good. Pin 70 has 12v. That connector is a pain to access on an e350. You have to detach from the outside of the firewall. And there is so much in the way. Frame, exhaust manifold, fuse box, heat protecting Aluminum shield....
Old Aug 2, 2019 | 07:12 PM
Breathe Together
So I pulled fuse s out to Insect again. Was dirty, so I cleaned and reinstalled. Now when I turn key there Is no power to anything
Old Aug 2, 2019 | 07:16 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I hear you, it ain't fun in my F250 either you have to pull the driver's fender well loose, I thought the van was a bit higher up and easier..... but it is good that now you know that 12V is going thru the connector .... now ya just gotta find where it don't make it to the inside Fuse box.
Breathe Together
The fuse itself is still good.
Old Aug 2, 2019 | 07:22 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
well, here is where Fuse 'S' Feeds the inside fuse box.....
Old Aug 2, 2019 | 07:34 PM
  #28
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I'll also tell ya that connector that plugs on to the head light switch is no fun either, they are known to Fry but fortunately you can get the replacement Pig Tail for it.
IF you are into the Dash I would sure inspect it while you are there.
here is a help link on that one IF you are interested.... https://www.fullsizebronco.com/forum...placement.html
I know this is off topic but that Black/Orange wire we have been chasing feeds fuse #4 also that goes to the Headlight switch
Old Aug 2, 2019 | 07:53 PM
  #29
Breathe Together
So ya. Now turning the key to on does nothing. Checked all fuses inside and out of cab. All have full continuity. And some have 12v. Would my ignition cylinder have gotten burnt? Idk what to think.
Old Aug 2, 2019 | 08:11 PM
  #30
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Are you sure you got C202 seated and screwed back in proper ?
the 10mm bolt needs a thin walled socket to get a good bite on it
just be careful not to cross thread that bolt in the center of the connector
