Need some help decoding a serial #
Old Aug 1, 2019 | 07:37 PM
kesselrun1's Avatar
kesselrun1
1964 F100 ser# F10CE491301
Old Aug 1, 2019 | 08:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kesselrun1
1964 F100 VIN: F10CE491301
Ford called it the serial number, but that's a misnomer, it's known as the VIN (Warranty Number on Warranty Plates). The serial number is the last 6 digits of the VIN
F10 = F100 2WD
C = 292 2V
E = Mahwah NJ Assembly Plant.
491301 = 1964 Numerical Sequence of Assembly, the trucks specific serial number.
128" Wheelbase.
BM: B = Caribbean Turquoise / M = Wimbledon White.
F100 2WD, 5000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Check Stripe Pattern Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / 3,300 lbs. Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
26 = Washington DC Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Sep 18, 2021 | 11:52 AM
johnnyidaho's Avatar
johnnyidaho
Bill
Can you help me with my transmission identification as I need to replace the output seal, thank you.
Old Sep 18, 2021 | 03:49 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Bill hasn't been on lately. That sequence number would be a 1969 model year. Transmission code 'A' is an NP435 4-speed.
Old Sep 18, 2021 | 04:38 PM
johnnyidaho
Thanks but it’s on my 59 f100 with 3 on the tree!
Old Sep 18, 2021 | 05:40 PM
85e150's Avatar
85e150
From this, all it says is "Ford 3 speed manual".
https://www.forelpublishing.com/demo/Demo20080.pdf
Scroll to page 25.
According to this, "Ford light duty":
https://www.ford-trucks.com/forums/1...nsmission.html
Parts source post 8, if this is the right transmission. Plenty of info to confirm with--9 bolt side cover?
https://www.ford-trucks.com/forums/1...lp-needed.html
https://www.drivetrain.com/parts-cat...d-overhaul-kit
Gesellman
Mar 27, 2019 02:00 PM
Murphy1966
Oct 30, 2018 11:04 AM
BeauF0RD
Apr 2, 2018 06:32 PM
Troy_Lee
Feb 17, 2018 12:14 PM
wyomingford
Jun 19, 2017 11:03 AM
