351m block drain locations
Old Jul 28, 2019 | 10:49 AM
packagerjr's Avatar
packagerjr
Attached is a picture of what I think this the driver’s side block drain plug. I could not feel the passenger side plug around the starter but haven’t dropped it yet. Can someone confirm the location of the passenger side plug? Thanks.
1980 Bronco, 351m
Old Jul 28, 2019 | 12:29 PM
Tedster9's Avatar
Tedster9
I think so. Pipe thread gives it away.
Old Jul 28, 2019 | 01:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A block drain....that's a new one to me. I'd take it out, and if water/antifreeze comes out, bingo. If oil comes out, not a block drain.
Old Jul 28, 2019 | 02:24 PM
Tedster9's Avatar
Tedster9
It's good to check or clear them in older engines, rust sediment and scale buildup becomes a problem though it wasn't a problem when they were new.
Old Jul 28, 2019 | 03:41 PM
FMJ.'s Avatar
FMJ.
It's a coolant drain plug.
The passenger side one will be at the front just under the exhaust manifold.
When you drain the block, drain the radiator first.
But stand back anyway coz the block holds a f$$k load of coolant, and there will be a mess.
Old Jul 28, 2019 | 05:26 PM
packagerjr's Avatar
packagerjr
Thanks group. I was surprised to see coolant at the thermostat when I removed it after draining the rad, but guess it’s the way the system is designed. Plus I got maybe 6 quarts out the rad which told me I’ve got more elsewhere.
Best I can tell, the drivers side looks like a 1/4” pipe plug. I’d like to pick up a dedicated socket just to reduce chance of round off. Can anyone confirm the size?
thanks.
Old Jul 28, 2019 | 07:38 PM
Ozzie H.'s Avatar
Ozzie H.
thanks.
You're lucky that they are square heads. My 460 had recessed Allen sockets, which rounded out when they were attempted to be removed after 42 years, requiring drilling out. I don't know the size. You can measure the size and buy an 8 point socket that size. If you flush/drain frequently you can put a valve in place of the plug. It makes cooling system flushing much easier and efficient. If it's never been out in 40+ years, it will likely be full of crud, and you'll have to dig it out with a wire. You may want to wear safety glasses or a face shield when doing the work. Sometimes it will come with a gusher. As mentioned, drain the radiator first.
Piolet
Sep 10, 2011 07:33 PM
High Binder
Nov 1, 2010 03:41 PM
motown
Oct 25, 2010 08:52 PM
cub 1947
Aerostar
Jun 24, 2004 02:41 AM
92Custom
Mar 8, 2002 06:11 PM
