Snap ring pickup coil
Old Jul 27, 2019 | 11:46 AM
damiunwalker's Avatar
damiunwalker
1977 Ford F150 6.6l 400
I'm having no luck removing the snap ring that holds the pickup coil on. I've tried prying up with picks. I've tried penetrating oil. Still no luck. Any suggestions?
Old Jul 27, 2019 | 03:35 PM
72rtchallenger's Avatar
72rtchallenger
Snap ring pliers
Old Jul 27, 2019 | 04:00 PM
vtpkrat2's Avatar
vtpkrat2
I have had reasonable luck with my pocket jackknife.Kind of slice it under the ring with the tip of the knife at the slot/break in the snap ring. Move knife slightly to use the sharp tip and pry up a bit. Be ready with something else like a very small screwdriver to slip under when the knife tip has a portion of the ring away. Can be a pain. Good luck1
Old Aug 1, 2019 | 07:04 PM
damiunwalker
I'm trying to remove the top nicked up piece, correct? It doesn't appear to be a snap ring to me.
Old Aug 1, 2019 | 07:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
12146 in pic is the 12151 breaker plate retainer. 351826-S is the "C" clip that retains the 12370 diaphragm rod.
Old Aug 1, 2019 | 07:33 PM
damiunwalker
thanks NumberDummy. So green is the piece I'm trying to remove. Orange appears to just be part of the shaft if I read your diagram correctly. Is this correct? Sorry for the confusion.
Old Aug 1, 2019 | 09:05 PM
NumberDummy
What you see in this parts catalog pic is all there is. I pointed out several of what the basic part numbers were for.
Old Aug 1, 2019 | 09:14 PM
Redrokin09's Avatar
Redrokin09
I used a 90 deg pick. Came out really easy, I didn't have much trouble with it.
Hanger53
Jul 15, 2019 07:19 AM
silverbullet6oh
Mar 13, 2017 10:00 AM
83sd
Sep 30, 2016 04:06 PM
William Mark Brown
Oct 7, 2015 04:27 PM
conyers73
Jul 14, 2013 08:17 PM
