Under Dash Pedal Bracket
Old Jul 25, 2019 | 04:21 PM
sonny1965's Avatar
sonny1965
I have a 1978 Ford F250 with a manual transmission and factory power brakes.
The bracket that bolts to the firewall and under the dash for the clutch and brake pedal assembly is broken
Is that bracket the same for all of the trucks or only for the manual transmission and power brakes
What will work?
What is the part number please?
Thanks for all of your help
Sonny
Old Jul 25, 2019 | 04:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The bracket that bolts to the firewall and under the dash for the clutch and brake pedal assembly is broken.
Is that bracket the same for all of the trucks or only for the manual transmission. Power brakes makes no difference.
D8TZ-1001508-A .. Brake & Clutch Pedal Support Bracket / Obsolete
1973/78 F100/350 & 1978 Bronco with Manual Transmission // 1979 F100/350 & Bronco with Manual Transmission before serial number AJ0,001.
No Ford dealer or obsolete parts vendor has any, none on ebay.
Shown as 01508 in upper/lower Bronco pics:
Old Jul 26, 2019 | 03:34 PM
sonny1965's Avatar
sonny1965
Thanks for your help Number Dummy
Sonny K.
Old Jul 27, 2019 | 03:06 AM
hail destroyer's Avatar
hail destroyer
Sonny, which bracket? Is it the clutch pedal bracket itself! This one?
I just repaired mine. It's a bear to work under there. If you need any tips or spare parts, lemme know, we have the same truck and apparently the same problems
Ron/RPMS
34
Jan 4, 2017 01:15 PM
smithriver101
18
Jun 14, 2015 08:55 PM
k_brenner
Mar 13, 2014 07:29 AM
81custom350
13
Oct 2, 2012 06:16 AM
loudfords
Jul 12, 2004 01:54 PM
