Under Dash Pedal Bracket
I have a 1978 Ford F250 with a manual transmission and factory power brakes.
The bracket that bolts to the firewall and under the dash for the clutch and brake pedal assembly is broken Is that bracket the same for all of the trucks or only for the manual transmission and power brakes What will work? What is the part number please? Thanks for all of your help Sonny |
Originally Posted by sonny1965
(Post 18770711)
The bracket that bolts to the firewall and under the dash for the clutch and brake pedal assembly is broken. Is that bracket the same for all of the trucks or only for the manual transmission. Power brakes makes no difference. 1973/78 F100/350 & 1978 Bronco with Manual Transmission // 1979 F100/350 & Bronco with Manual Transmission before serial number AJ0,001. No Ford dealer or obsolete parts vendor has any, none on ebay. Shown as 01508 in upper/lower Bronco pics: https://cimg1.ibsrv.net/gimg/www.for...55ff4f5a8f.jpg https://cimg6.ibsrv.net/gimg/www.for...fef7f111cd.jpg |
Thanks for your help Number Dummy
Sonny K. |
Sonny, which bracket? Is it the clutch pedal bracket itself! This one?
https://cimg7.ibsrv.net/gimg/www.for...c1c568223f.jpg I just repaired mine. It's a bear to work under there. If you need any tips or spare parts, lemme know, we have the same truck and apparently the same problems |
