Rear AC not working
Old Jul 25, 2019 | 05:55 AM
RyanMac119's Avatar
RyanMac119
Rear AC not working
She blows hot air. Fan speed control works, rear controls work, it just blows hot air. Could this be a blend door issue? Doesn’t the Ex have a separate condenser for the rear Ac?
Old Jul 25, 2019 | 06:23 AM
projectSHO89's Avatar
projectSHO89
Maybe. Can you vary the rear outlet temp from near ambient to HOT and back again as you change the setting? Need to distinguish between a "loss of A/C (cooling)" vs. "complete loss of temperature control, output stuck on one setting".
Non it has a separate evaporator for the rear unit's A/C. There's only one condenser up in front of the radiator.
Old Jul 25, 2019 | 07:16 PM
RyanMac119's Avatar
RyanMac119
No variation in air temperature at all. It stays Warm.
Old Jul 25, 2019 | 07:43 PM
projectSHO89
That does sound like an actuator.
Old Jul 25, 2019 | 07:51 PM
rsqfxr's Avatar
rsqfxr
mine did this, since i didn't need the rear air to blow on the floor i just swapped the actuators, now i have cold and hot air
Old Jul 26, 2019 | 03:43 AM
RyanMac119's Avatar
RyanMac119
Where are the actuators located?
Old Jul 26, 2019 | 01:13 PM
DavenTn's Avatar
DavenTn
Is the line going into the evaporator cold? Typical failure (screen gets clogged) is the rear expansion vale.
Old Jul 26, 2019 | 02:07 PM
projectSHO89
Based on his responses, his first problem is that he has zero control over the outlet air temp, even before considering the effect of refrigeration.
Old Jul 27, 2019 | 08:02 AM
alloro's Avatar
alloro
For the rear you have to remove the right rear panel.
Old Jul 27, 2019 | 09:21 AM
RyanMac119's Avatar
RyanMac119
Thank you very much.
Old Jul 28, 2019 | 09:38 PM
Dieseldope's Avatar
Dieseldope
Ruanmac
. Is the compressor kicking on ? If no there is a switch near the compressor its a low presureswitch while the switch for ac is on keep the connector connected and wiggle the wire ends. Sometimes this works. Ac is1 big system has one of everything but blower motors and switches. The air is moved thru a duct in the ceiling.
Old Jul 28, 2019 | 09:53 PM
cebemis's Avatar
cebemis
I had the same issue. I replaced the rear expansion valve located behind the jack. It was like 30 bucks at autozone.
Another 40 bucks worth of refrigerant because the system opens up while replacing the valve. I replaced the orifice tube while the system was uncharged too.
Recharged it and rear blows cold again.
breyer123
2004 - 2008 F150
Jun 18, 2017 12:58 AM
Macmathews
Jul 23, 2010 04:47 PM
chaneyb
Aug 20, 2007 09:53 PM
elinkieto
Jun 21, 2007 07:39 AM
03chateau150
Dec 2, 2006 11:32 PM
