o2 sensor problem code 135
Old Oct 6, 2003 | 11:17 AM
Jimmat's Avatar
Jimmat
I have a 2000 ford ranger with 4 cylinder engine. I am getting a code of P135. I have checked the heat in the front sensor it reads 4 ohms. I got a schematic and checked voltages at the PCM. I found that the ground at pin 95 is delayed about a minute before making ground. I am using a volt meter on pin 95 and am reading 12 volts until the ground makes. I can read pin 93 with the volt meter and the ground makes as soon as I start the engine. If you can help me with this problem I would appreciate it.
Thank You
Jim
Old Oct 6, 2003 | 01:04 PM
Franklin2's Avatar
Franklin2
My book doesn't go that late, and I can't look up the code. Plus I don't have any schematics that late either. But what I can warn you about, is a "ground" on a pin is usually a sign that the circuit is active.
Most of the computer circuits on vehicles work in reverse of what you normally think. They usually send 5 or 12 volts out to the sensor, or motor/coil/heating element all the time, as soon as the truck is started. But none of this stuff has a complete circuit back to the negative of the battery. Instead, the negative goes to the computer pin, and the computer "grounds" the wire inside with the electronics. So when you read 12 volts on a pin, that means the heater element has 12 volts on both of it's terminals, so there is 0 volts across it. The negative going to the computer pin floats up to 12 volts. When the pin at the computer goes negative, that means the computer is turning the element on, having 0 volts on one side, and 12 volts on the other(the constant feed 12 volts).
Old Oct 6, 2003 | 05:22 PM
Jimmat's Avatar
Jimmat
Pin 95 seems to ground after a minute or two, where as pin 93 which is the ground for the other sensor grounds the second I start the engine. Pin 95 is delayed. I think this is why I am getting the code P135.
need help
Thank you
Old Oct 6, 2003 | 05:37 PM
Franklin2's Avatar
Franklin2
I looked up p135 and it is a o2 heater circuit malfunction(of course you knew this already?). I would check the wiring carefully, especially if you had any exhaust work done recently. Have you tried replacing the sensor?
JimsRebel
'80-'86 HOWTO's
18
Jan 23, 2025 04:19 PM
mikeheckler
1997 - 2003 F150
Sep 17, 2015 11:38 AM
blue84f250
May 19, 2013 11:23 PM
Jimmat
Electrical Systems/Wiring
Jan 22, 2010 07:05 PM
Jimmat
Sep 2, 2003 05:46 PM
