DTE and Actual empty
Old Jul 24, 2019 | 09:27 AM
Archaea's Avatar
Archaea
2018 gas F250 longbed. The truck should have a 34 gallon tank, but I've never put more than 26 and change at a fill up. Last weekend I took a trip and went down to 30 and 50 miles DTE and still 26 gallons at the pump (with camper I was averaging 12.5 MPG on both tanks)
Is this normal? I'm planning a much longer trip shortly and would like to minimize stopping, the 8 gallon reserve seems a bit excessive.
Old Jul 24, 2019 | 10:04 AM
Sport45's Avatar
Sport45
You could throw a 5-gallon gas can in the back and run it to actual empty to find out for yourself...
What you may find out is the total volume is not the same as the usable volume. While your tank may well hold 34 gallons from empty some minimum level is required to cool the fuel pump, provide emergency range to reach a station, etc. I'll guess you have about 28 "usable" gallons running the DTE to zero.
Old Jul 24, 2019 | 10:15 AM
Alleydog's Avatar
Alleydog
The DTE # is a guestimate at best. The DTE miles countdown never matches the actual odometer #, sometimes it close but most of the time its no where near actual. If you get down to a quarter of a tank or less on the fuel guage, I would be looking to fuel up.
Old Jul 24, 2019 | 10:28 AM
mrgrayaz's Avatar
mrgrayaz
Yes, normal for the shortbed. Many complaints on it. 8 gallon reserve is indeed a ridiculous number. Mine does the same damn thing. I run the DTE to 0, but as much as you know it, its hard with the thing dinging you constantly.
Old Jul 24, 2019 | 10:33 AM
Archaea's Avatar
Archaea
I see in your sig you've got a 30 gallon auxiliary! I was hoping to get at least 300 between fill ups on my cross country trip. Right now when the gauge is "empty" I'm consistently at 8 gallons left. That would mean at 1/4 I'm at 14 gallons left. I'm not a risk taker but that means filling up every 225 or so miles on the remaining 20 gallons.
Not to whine but the giant fuel door on the truck means removing the camper tie downs every fill (the frame mounted tie downs are in exactly the wrong spot). It gets old.
Old Jul 24, 2019 | 10:45 AM
crewzer's Avatar
crewzer
Lightbulb
The “34 gallon” tank on our 2019 F350 6.2 crewcab short bed takes ~30-1/2 gallons when DTE gets down to about zero. I’m OK with an ~10% reserve. 300+ miles per tank is doable unless driving uphill and/or into a strong headwind.
I use TorkLift Fast Guns for our camper’s front turnbuckles. Removing the driver-side TB when refueling adds less than a minute to the pit stop.
Finally, switch your DTE calculation from “Normal” (?) to “Towing”.
HTH,
Jim / crewzer
Old Jul 24, 2019 | 11:09 AM
Kaadk's Avatar
Kaadk
That's pretty much what I plan on, by 200 miles or so, I'm looking for a top up on the fuel. Averaging about 7.9 mpg when towing the fiver, I don't want to get stuck with a 'I have to fill up now' situation, and then have to worry about easy access around gas pumps. The fiver's better at maneuvering than my old bumper pull, but I had enough situations with the bumper pull to make me weary about fuel ups.
Well, yep, that would make it harder to fuel up more often. Have you considered removing the fuel door before strapping the camper down? I'm not sure if they can be removed easily, but if they could, at least you can fill up without having to unstrap your camper.
Another option might be to look at a replacement tank. They don't make them for gassers, (there was a post a little while ago about that: https://www.ford-trucks.com/forums/1...l#post18682632) but if you've got a diesel, there are replacement tanks available.
Old Jul 24, 2019 | 11:15 AM
divingmikeboats's Avatar
divingmikeboats
Pulling trailer last month I pulled in to fill up just as DTE hit 0 miles and put in 32 gallons. I don't know if I'd depend on getting to use that last two gallons though. 2019 F250 6.7
Old Jul 24, 2019 | 07:03 PM
1olddogtwo's Avatar
1olddogtwo
I thought long beds had 48 gal tanks
Old Jul 24, 2019 | 07:26 PM
Kaadk's Avatar
Kaadk
Only the CC ones, the other cabs are 34, even in the LB.
Old Jul 24, 2019 | 09:59 PM
Coghlin's Avatar
Coghlin
I have a 2019 f450 cc. I have run out when the dte says 2 miles left when towing. I also had it say 0 miles ànd I made it another 5 miles. I then filled up with 48 gallons. Mine leaves no reserve. I regularly fill with almost nothing left. I noticed when not towing or loaded there is more reserve I guess because of the angle of the truck. Fuel gauge must be closer to the back of the tank.
troverman
Jan 20, 2022 11:31 AM
got2bjoester
Escape & Escape Hybrid
Apr 21, 2017 08:10 PM
barrelhorses
Modular V10 (6.8l)
18
Dec 7, 2008 09:38 PM
yamahonda41
Feb 1, 2006 07:30 AM
Bad Company
Sep 28, 2004 02:21 PM
