Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Fuel Issues - 2003 3.0L
Old Jul 24, 2019 | 05:42 AM
Fuzzpuss's Avatar
Fuzzpuss
My wife's Escape was showing signs of a failing fuel pump (hard starting, wanting to stall at stoplights) so I scanned it with AE and found no codes but the "fuel pump duty cycle" PID showed 100%. I figured the pump was just worn out, and at 300k I figured it was time for a new one, so I replaced it. So far the car starts and runs fine, and fuel pressure at the rail measures 60psi with a test gauge with the engine running. When I stop the engine the pressure drops to 50psi immediately, 40psi after a few minutes, and 20psi after a few hours. I just replaced the fuel injectors 6 months ago with Motorcraft parts. Could they already be leaking that badly? Or would a faulty fuel rail damper cause this?
Also, the fuel pump duty cycle is still showing 100%. I did a voltage drop test at the pump and the power side had a drop of 0.9 volts. It seems that with a significant drop like that, the engine wouldn't be getting enough fuel and not the other way around.
Old Jul 24, 2019 | 07:25 PM
projectSHO89's Avatar
projectSHO89
On an 03, fuel pump duty cycle is always 100% unless the pump is OFF (then it's 0%). It's not a variable duty cycle pump.
Most likely, you have a pressure regulator on the pump module. Did you replace the whole unit or just the pump motor?
If you had an injector problem, you would know it (hydrolock, gas in oil, black smoke on startup). The damper cannot cause your issue.
Old Jul 24, 2019 | 08:24 PM
simonsi's Avatar
simonsi
I wouldn't worry about that leakdown of pressure over that time period at all. Likely it is entirely normal back drain through the pump when off. Gas is an incompressible liquid so that pressure drop represents a tiny volume of fuel draining back through the pump assembly.
Old Jul 25, 2019 | 07:59 PM
Fuzzpuss's Avatar
Fuzzpuss
I replaced the whole sender unit.
I called Delphi's tech support line. They said to bleed down the pressure to 10psi, and if it drops more than 2psi in any 5 minute period then it fails.
I also asked about the duty cycle and at first he said 100% is normal, it's "like a light switch", then after explaining my reasoning, he said the voltage should vary. I think he was caught up in the thought that the car has a fuel pressure sensor on the fuel rail, even I told him it doesn't. Then he said to check the fuel pump control module. I called Ford, gave them the VIN, and they said it doesn't have one.
After reading your replies I feel better, the wife feels better, and I"m not going to worry about it. Thanks for your input guys!
Old Jul 25, 2019 | 08:49 PM
simonsi's Avatar
simonsi
Yep sounds like your pump is holding pressure way over that threshold ��
rsanford
Nov 12, 2017 02:34 PM
99f350sd
Aerostar
15
Jan 23, 2017 12:48 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Apr 21, 2015 12:20 AM
40LUTZAG
1997 - 2003 F150
Nov 2, 2010 08:01 PM
krzyk26
Mar 29, 2005 05:49 PM
