Advice needed
Old Jul 23, 2019 | 09:16 AM
Markus Luukko's Avatar
Markus Luukko
Advice needed
I’m helping a friend of mine out with his truck.
It will randomly shut off and is low on power.
i used my autoenginuity to test the ICP IPR and IPW. Attached is a link to a video of the WOT test. As seen the ICP is very low while the IPW and IPR% are high leading me to believe he needs a new HPOP. I am going to let him try my ICP to see if that’s the issue before buying a HPOP. Any other suggestions, not my truck so I don’t want him to spend money before we truly diagnose it.
Old Jul 23, 2019 | 11:07 AM
Tugly's Avatar
Tugly
Your scale factor on your FIPW is off. You are reading in seconds, when you want milli- or microseconds. The FIPW on the top right shows you running 5.4 ms at WOT, and that sucks ICP down like a big toilet swirl, then the ICP will skyrocket when you let off the throttle all at once. Look at the 2600 ICP with 10% IPR and 0.6 ms of FIPW (off) in the last seconds. You have a hot performance tune in there. Get back to stock or lower the HP tune and watch the results.
As for stalling, CPS might have failed - or that IPR has a loose tinnerman nut, or it's overheating and failing.
Old Jul 23, 2019 | 11:09 AM
Markus Luukko
From what he told me it’s on the stock tune. Truck had 130k on it and my 320k truck with 180/30s and a factory HPOP makes more PSI in a hot tune than his stock.
I told him to buy a CPS, and we already checked the IPR. I don’t think it’s the typical IPR fails when hot, I had that issue and this doesn’t seem to be a similar case as we tested at 190*+ oil temp
Old Jul 23, 2019 | 11:11 AM
Tugly's Avatar
Tugly
You can try a Cody test, to see if he has bad injector O-rings, or we're back to that IPR. HPOPs fail far less frequently than IPRs and O-Rings.
Old Jul 23, 2019 | 11:16 AM
Markus Luukko
If his o rings were bad wouldn’t he have a oil consumption issue?
Old Jul 23, 2019 | 05:31 PM
Tugly's Avatar
Tugly
Not necessarily. If the top O-Ring is shot, the oil can ooze up under the valve cover, to make an aggressive oil recycle.
Old Jul 25, 2019 | 07:48 AM
HKusp's Avatar
HKusp
Yes he would, depending on which set of O-rings it is.
Old Jul 25, 2019 | 10:36 PM
HD Rider's Avatar
HD Rider
I didn't think stock tuning would even allow that much pulse width.
JonathanN
13
Jan 19, 2012 08:52 PM
540milotalon
Nov 3, 2011 09:03 PM
CPUNeck
Jan 3, 2010 08:21 AM
bigtimebubba
43
Jul 18, 2009 05:54 AM
pwheeler94
Apr 3, 2007 09:40 AM
