97 Auto Trans Failures
Old Jul 21, 2019 | 12:16 PM
KelsterB's Avatar
KelsterB
I'm so fed up with the crappy automatic transmissions that come with Ford trucks that I'm ready to give up on Ford all together and switch to GM just to get an Allison. I've had two diesel trucks with E4OD's which have been problematic. The first lasted 2 years after a rebuild, never shifted properly and eventually started slipping in 3rd. The second truck made it to about 240,000 km then started to mishift in 3rd and lasted about a month after a $3000 rebuild and won't shift into 3rd after some heavy duty towing. So what's the secret to building a bullet proof E4OD or are they just **** and I should quit burning good money on these SOB's?
Old Jul 21, 2019 | 12:22 PM
z31freakify's Avatar
z31freakify
800k miles on mine and still going, added a triple disc low stall TC and bigger trans cooler, but it always had an upgraded trans cooler with a dedicated fan from day 1.
Seems the trans builder didnt know how to build one properly.
You think E4OD is bad theres nothing special about the allison either and are a common failure on Chevys and are even more $$$ to repair.
Old Jul 21, 2019 | 05:03 PM
Hit Man X's Avatar
Hit Man X
You may as well go buy a GM as your mind is made up.
Two years on a rebuild equals a garbage rebuild. Blaming Ford for that is foolish at best.
Old Jul 21, 2019 | 05:45 PM
ford390gashog's Avatar
ford390gashog
Step one is you need a qualified and respected rebuilder and most often it's not your local transmission shop. I went with the John woods HD tow master E40D and had almost 200k on the unit when I sold the truck with no issues and that was like ten years ago. I believe back then it was almost 4k for the transmission. Any E40D rebuild under 3k should be suspicious as there is a considerable cost in good parts and the skill to build one.
Old Jul 21, 2019 | 07:27 PM
quesey's Avatar
quesey
I have to disagree on that cost.lol
But I build my own. Yes there is tricks to building a good trans. I say when you spend that much that you are really just paying for the warranty.
Triple disk low stall and everything in mine was under $750.
Now for those that dont build they will have to pay for the person that does build them
Old Jul 21, 2019 | 08:26 PM
Hit Man X's Avatar
Hit Man X
That is why I like you, John...you are sick and build your own like me!
Hell, I am currently building a ZF 4HP22 w HP24 guts!
Old Jul 21, 2019 | 08:29 PM
z31freakify
Looking good by the way Eric
Old Jul 22, 2019 | 07:39 PM
quesey's Avatar
quesey
lol
Thanks just a poorboy trying to keep his junk running
Leemakesmepee
Oct 31, 2011 10:15 AM
phoenix44
Sep 16, 2009 07:04 PM
LeoJr
Nov 25, 2006 07:45 PM
redneckf350
Feb 3, 2005 10:12 PM
