Sponsored by: Real Truck
7 blade plug
Old Jul 21, 2019 | 11:59 AM
Ivan Solkey's Avatar
Ivan Solkey
7 blade plug
My 04 SD has the optional 7 blade connection in the bed, I'd really like to be able to hook my inverter to it and have AC power in the bed, anyone know of a conversion cord, or diagram to make that happen?
Old Jul 22, 2019 | 09:33 PM
donjamer's Avatar
donjamer
Moved to appropriate forum - Donjamer
Old Jul 23, 2019 | 05:00 AM
Just Strokin's Avatar
Just Strokin
Old Jul 23, 2019 | 10:51 AM
Sebs's Avatar
Sebs
If I understand your question, you want to get 12v power from the 7 pin connector to power an inverter in the bed. Looking at the above post the battery and ground are the pins to use for the input to the inverter. That is only a 30 amp circuit so you only have available about 390 watts into the inverter so you are limited to an inverter that outputs less than that.
tuckdaway
Aug 7, 2017 03:46 PM
F350GK
13
Jul 12, 2016 06:54 PM
kenttrudiw
2015 - 2020 F150
15
Jul 13, 2015 05:57 PM
Lastwagen
6.7L Power Stroke Diesel
13
Jan 25, 2013 09:01 PM
