Widow Makers?
Old Jul 21, 2019 | 09:13 PM
poppatello's Avatar
poppatello
These are the wheels on the 65 N600. Current owner doesn’t know if these are widow makers or not. Can u folks tell?
Old Jul 21, 2019 | 09:27 PM
85e150's Avatar
85e150
N650 wheels are definitely WM.
Old Jul 21, 2019 | 09:33 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
You’re the guy buying the widow makers. The N600 has the 6 x 8.75” pattern so if you can spend some yard time you’ll be able to find a used set of 22.5” x 6.00” or 6.75” tubeless replacements. You’re lucky it’s a 1965 and not a 1963/64 because they had hub piloted widow makers. The buyer of your truck needs to start looking for a set of tubeless 17.5s. Stu
Old Jul 21, 2019 | 09:44 PM
poppatello's Avatar
poppatello
Damn. Both trucks have new tires on them.
Old Jul 21, 2019 | 09:52 PM
truckdog62563
You can also go the military surplus route on the N600. These old threads discuss it. Stu
https://www.ford-trucks.com/forums/1...s-on-f600.html
https://www.ford-trucks.com/forums/1...em-solved.html
Old Jul 21, 2019 | 09:57 PM
Tedster9's Avatar
Tedster9
Originally Posted by Crop Duster
I changed a million flats on trucks with that type of rim when I was in the Air Force. Never died from it once.
Truck tires like you're talking about, with a split ring, are not the same thing as "widow makers".
Old Jul 21, 2019 | 09:59 PM
bigwin56f100's Avatar
bigwin56f100
Just to let everyone know I have 2 17.5" rims with tires. Stu (truckdog) messaged me
Old Jul 22, 2019 | 08:12 PM
85e150's Avatar
85e150
If those tires are in good condition, run 'em. There is always a chance a WM will let go, but that's probably not going to happen if they are rust free, and have been mounted up for a while. ("proven" so to speak) The real danger is airing them up after a tire change. Airing them up period is a risk.
From the looks of both trucks, you have some work to do to bring that N up to the level you had that F350.
Good luck with it!
Old Oct 7, 2019 | 05:04 PM
bigwin56f100
Just bumping up to the top I just picked up 6 rims with new tires if anyone is looking
17.5” tubeless 6 lug
Old Oct 7, 2019 | 05:32 PM
truckdog62563
To clarify about Kevin’s wheels. These are the 17.5” tonner tubeless wheels having the 6 x 7.25” pattern. They are Budd 79120s having three hand holes each. Stu
Old Oct 8, 2019 | 05:31 AM
User 71024's Avatar
User 71024
Just my 2 cents. I did my fair share of split rims when I was a kid. Never liked them, and although they are not all "widowmakers", there was a patch in the roof of Rolands tire(?) in New Bedford over the tire machine where a 20" lock ring went threw the roof, passing threw the neck of the installer.Not 100% sure it was Rolands, but I think it was. That gave me a great deal of respect for all split type rims. My father taught me to bolt the wheel on the truck backwards with the lock ring facing in before inflating them, that way if it does get loose, nobody dies. They also make tire cages that you roll the wheel into before inflating.
If I owned a split rim truck that needed tires, I would more than likely go to solid rims.
And as a side note that I did not see in this thread yet, I remember, I believe it was a ford with a 2 piece lock ring. Only remember one truck with it and my memory kinda sucks, but I though it was an early 70's F-500. Bill might be able to enlighten us on that. And I believe both rings where continuous.
Oh and another thing, that rim in the early part of the thread that you can see threw is definitely a bent rim. The notch that some of them had for the tire tool was a rectangular cutout. That is definitely a dent and should be straightened.
Eric
Old Oct 23, 2019 | 06:38 PM
PRattenbury's Avatar
PRattenbury
I am looking for a set of 6 wheels for my 62 F350 dump truck. 6 on 7.25" bolt pattern. If these are available I would be interested in them if they are what goes on my truck and the price is right.
Old Oct 30, 2019 | 05:54 PM
  #28
Thunderkiss1965's Avatar
Thunderkiss1965
'52 F-3 Marmon-Herrington 6R32-4 - in progress
'51 F-3 Marmon-Herrington R3-4 - in progress
'51 LD7-4 M-H Ranger - safe and dry, gathering pieces
Hey, Truckdog. Saw your collection in your signature and saw my name! My name is Daniel Marmon. If I'm a direct descendent, I don't know where the money went!
Old Oct 30, 2019 | 06:28 PM
  #29
truckdog62563
Since the company still exists and is today still doing AWD conversions, you might trace your family tree to see if your birthright awaits you. Stu
https://www.marmon-herrington.com/awd-conversions
Old Oct 30, 2019 | 06:49 PM
  #30
bigwin56f100
The set of 6 have been sold
I do have 2 more rims with really nice steer tires
I sent you a PM
