I have a 92 f150 302 engine, e4od trans. 3.55. Gears. I'm considering a gear change . I live in rural Co alot of long up hill grades. I trailer two atv and equipment. My truck is doggy on the hills. I'm having trouble deciding between 3.73 or the 4.10. I'm concerned about excessive rpms. I very rarely drive over 65. My truck is totally stock. Has anyone done this swap. What would you all recommend. I'm leaning towards the 4.10 to justify the expense of the swap. What rpms would my truck run at 65 with the 4.10 gears. Also it's a 2wd trucker. Thanks
I had the same setup as you when I still lived in Colorado and changed mine out to 4.10. With stock 29" tires I run around 2,500 RPM at 75mph. I wouldn't go any higher than 4.10, especially if I had tires larger than stock. In fact, if I still lived out there and had the 302, I'd go with 4.56.
I went from 3.55 to 4.10 in my 92 F250 4x4 460/E4OD. Love it for towing heavy, no regrets. If running empty on hwy sort of feels like it needs another gear but I was used to the 3.55's so probably why. Love the 4.10's. This is with 265/75/16 tires. Mine turns 2000 RPM at 65 MPH. I did reset PSOM best I could to match tire size/rotations per mile.
Reason: added info
