Blower motor issues
Old Jul 21, 2019 | 07:49 AM
ihf-350's Avatar
ihf-350
Blower motor issues
Good morning,
Does anyone happen to have a wiring diagram for a 77 f100 I have been to fordification and 77 is skipped and the owner says he can’t find his 77 book. I tried working off of the 76 diagram but there are small differences and the 78 is nowhere close.
Old Jul 21, 2019 | 08:52 AM
dlburch's Avatar
dlburch
what symptoms are you having, and what have you already checked? and do you have factory AC?
Old Jul 21, 2019 | 10:34 AM
ihf-350's Avatar
ihf-350
I have factory ac I have checked the switch with an ohm meter it functions as it should if I apply 12v to the fan switch connector all 4 speeds work. I have 12 v coming out of the orange and green and white wires on the function switch. Ac compressor is running and the condenser is cold and when I turn the fan on with a wire it blows cold. In the 76 wiring diagram it shows a relay and it says in the engine compartment in the middle of firewall. I have nothing there. On the 78 diagram there is no relay at all.
Old Jul 21, 2019 | 12:25 PM
dlburch's Avatar
dlburch
do you have a red wire with a black stripe? I THINK that is the wire that feeds power from the ac mode switch over to the fan switch...
Old Jul 21, 2019 | 01:18 PM
Bulldog187th's Avatar
Bulldog187th
Hope this helps it from my 77 shop manual ,
Old Jul 21, 2019 | 01:22 PM
Bulldog187th
Just in case you need this
Old Jul 21, 2019 | 01:31 PM
Bulldog187th
I just got done wiring mine the blower switch last week. I made a video let me see if I can get it to load up so you can watch it
Old Jul 21, 2019 | 02:01 PM
ihf-350's Avatar
ihf-350
That diagram was exactly what I needed so it is similar to the 76, which brings me to the next question where is the relay
Old Jul 21, 2019 | 02:03 PM
Bulldog187th
I have no rely in mine. I trying to get the video off my iphone to load it up here.
Old Jul 21, 2019 | 04:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ihf-350
Good morning,
THREE different types of A/C in these trucks, factory and two types of dealer installed A/C
Most people don't know one type of A/C from another.
Factory installed integral A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
At the right rear of the engine compartment, is the HUGE factory A/C evaporator case.
The factory A/C blower motor and blower motor resistor are the same 1973/79.
Some 1973/75's use different parts than 1976/79. If the part fits a 1976, it'll be the same thru 1979.
Blower motor resistor shown as 19706 in pic. 19618 is the A/C evaporator temperature control thermostat. 19849 is the expansion valve.
Old Jul 21, 2019 | 04:25 PM
Bulldog187th
Here is the video , sorry it only like my 2 one i have ever made
https://www.youtube.com/watch?v=B5Jq...ature=youtu.be
Old Jul 21, 2019 | 06:09 PM
ihf-350's Avatar
ihf-350
Mine is the factory air and the resistor is functioning properly, along with all the ac components. It is just the fan not working and no voltage to the fan speed switch.
Old Jul 21, 2019 | 06:10 PM
ihf-350's Avatar
ihf-350
Old Jul 21, 2019 | 06:17 PM
dlburch's Avatar
dlburch
here is a thread with a picture of the relay. I always thought the relay was a 1976 only thing...but if you '77 has it, you can follow the yellow w/red strip wire from the mode switch and it should lead to the relay...
Old Jul 21, 2019 | 07:11 PM
ihf-350's Avatar
ihf-350
It disappears into the harness I will try to track it down out cruising it now lol.
