90 F-150
If it was mine...
I'd open up the motor & bend the contact fingers just a tad to improve their tension and maybe clean up excess debris and grease.
There also is a procedure here on site on repairing the speed selector switch on the stalk, if I could find it.
Failing that, I'd replace the multi-function switch in it's entirety.
Sorry, can't give you the rewire info you want, but you hadn't gotten anything so far.
Good luck.
Good luck.
If it was mine...
Good luck.
Good luck.
Maybe its it’s just been my good luck but I have never had a wiper delay module go bad. More often than not it is the motor that has failed. I got a couple junk “remanufactured” wiper motors from Napa. The last one I got was a Cardone and it has been great so far. What is failing in the modules? Could the motor be pulling too much current burning them up?
The non intermittent wiper is a two speed ( low / high ) setup.
On the ‘87-91 trucks, turning the switch clockwise is for low and high speed. Counterclockwise is for intermittent wiper settings. Couldn’t you have just not used the intermittent function?
How does replacing the switch bypass the wiring to the intermittent control module?
For me intermittent wouldn't work and low was on/off. High was working fine. The low/high switch plugs right into the plug that goes to the wiper motor taking out the entire control module out of the equation. If I remember correctly it will not fit the plug to the module. Now I have high/low wipers bot no delay. At a minimum it's a tool to help diagnose the issue before you replace the wiper motor. I suspect my module is fine but a wire is bad but I haven't found a wiring diagram nor the time to test the harness. Since it's working for me it's not high on my to do list.
1972RedNeck
20
08-19-2013 08:20 PM
Tony_C
01-20-2012 12:10 AM
