VSM Failure
Old Jul 19, 2019 | 10:38 PM
samenewstory's Avatar
samenewstory
Trailering
VSM Failure
Hey Guys,
I've scoured the internet and these forums, and please forgive me if this has already been discussed, I have definitely done my searching. I was just gifted a 2002 Ford Excursion V10 2WD (YAY ME! I've always wanted an Excursion, preferably a 7.3, but free is free). It's got 179k miles and its door ajar light is permanently on, no power door locks, auto headlights don't work, door keypad doesn't light up or function (I've got the code for it), radio doesn't turn off when I turn off the truck and open a door. I scanned it with FORScan over OBD and when all the doors are closed, they show closed via the OBD2 port. I've lubed the $%&# out of each latch, even replaced the driver's door lock actuator and the power door locks still don't work. So, I'm convinced I've got a bad VSM. The part number I've found online is 2C7T-15K602-AJ, but I only see this part number when discussing 7.3s and Superdutys, I just want to verify that that is the correct part number for a 2002 V10. I'm very mechanically inclined, (can't program it, so will probably have to go to the stealership and get it programmed.), but I can install it! Other than that the truck is perfect mechanically, can anyone verify that I have the correct part number for the VSM. I want to take good care of this truck and get it back in proper shape.
Again the part number I have is 2C7T-15K602-AJ.
Any help or advise is greatly appreciated! Attached is a pic of the truck, for attention hahaha.
Please don't chastise me if I missed something in the search feature, and I'm looking forward to being a member on this forum.
Thanks in advance!
-Christopher
Old Jul 19, 2019 | 11:29 PM
Restlesswildman's Avatar
Restlesswildman
Is there a salvage yard near by that you can go get a master switch for the drivers door? That can sometimes be the issue. Have you checked the wiring between the door and door jams? I had a lock issue and found 2 busted wires in those areas.
Also there is a place listed on FB out of Moorehead, KY that might be able to help you. The specialized in SD parts.
Old Jul 19, 2019 | 11:44 PM
samenewstory
Trailering
I don't think it would be the master switch, because the passenger switch doesn't work for the door locks either, I haven't pulled the wiring loom out to check for any busted wires, but I will do that in the AM. There are some salvage yards near me. Thanks for the quick reply! I'd be surprised if all 4 doors wires and the hatch were busted, but def looking into. Thanks again!
Old Jul 20, 2019 | 05:39 AM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum and family Christopher!
Unfortunately (for you, fortunately for me ) I don't have any input on your electrical gremlins or the VSM issue. But I just want to say that a RWD V-10 XLT like yours would be a great rig to serve as a tow rig and would be high on my list if I had to start all over again. And I see that yours has the larger towing mirrors, do you know which gear ratio it has?
Old Jul 20, 2019 | 10:55 AM
PrescottIce's Avatar
PrescottIce
More info, please. And a few things to check...
Does it unlock with the key fob? Will it start? Any indication from the THEFT light? I'd lean toward the VSM if it didn't unlock, start, or had strange THEFT light behavior.
Any abnormal behavior with the windows? Interior lights work as designed? Do you get a door chime with all doors closed? If you have illuminated running boards, do the lights stay on when the doors are closed?
Did you remove and clean/check all fuses? These trucks can develop a windshield leak, which results in the fuse panel getting wet and causing intermittent connections. One of the clues can be some rust on the blades of the bottom row of fuses.
This sounds silly, but try pounding on the dashboard, in the middle of the cluster over the top of the speedo. Someone will correct me if I'm wrong, but I think in 2002, many functions of the GEM were moved to the instrument cluster, and over time some of the solder connections can become wonky and intermittent - eventually failing the functions entirely. The auto headlights seem to be more a symptom of the GEM... hey, it's something free to try. There's also a battery saver module (also on the cluster) that affects the radio shutoff, but that may be a different rabbit hole.
Old Jul 20, 2019 | 01:36 PM
samenewstory
Trailering
Thanks for the warm welcome! Mine has a 3.73 axle ratio with the LSD
Last edited by samenewstory; Jul 20, 2019 at 06:15 PM. Reason: Additional information
Old Jul 20, 2019 | 01:46 PM
samenewstory
Trailering
I only have a key for the car, no fob, the previous owner said the alarm was going crazy so they “had it disabled”, maybe it was aftermarket? Or exhibiting the issues you’re describing, they’re not “car people” so it’s hard getting anything out of them. I tried to buy some remotes but I have no way of knowing if I successfully programmed them because the door locks don’t work. One of the first things I noticed when I took delivery of the car was part of the weatherstripping on the underside of the windshield from the middle all the way to the drivers side can basically be pulled off and hung off the car, it looks like old, warm out wiper blade rubber. I have noticed some signs of water intrusion on the fuses, but all are still good. We don’t get much rain in Southern California. The theft light blinks constantly, I do not have any of the other issues you’ve described.
With your permission I’m gonna go whack my 17 year old American plastic dashboard and hope to god it fixes everything! Hahaha, thanks for the reply!
Old Jul 20, 2019 | 02:03 PM
Mikei70's Avatar
Mikei70
Check the GEM module for water. If your fuse box shows signs I would imagine the GEM module was exposed as well. It's that box that sits on the back of the fuse block.
I had some weird issues and that turned out to be the culprit. Fortunately I was able to clean it up and it has worked fine since.
Old Jul 20, 2019 | 02:06 PM
samenewstory
Trailering
I thought the 2002s didn’t have a GEM, they have multiple different control units, I could be wrong. I’ll check regardless.
Old Jul 20, 2019 | 04:59 PM
Mikei70's Avatar
Mikei70
Oh you might be right. I have a 2000.
Old Nov 22, 2019 | 01:15 PM
78CJ5's Avatar
78CJ5
Hi Everybody.
I just got a 2002 Excursion V10 4WD and the owner got it from told me it has a VSM Issue. The Little Red Light in the Center of the Cluster is on (if I take the Ground off the battery and put it back one it does out for awhile,
So I have been watching for a Excursion and they are hard to find for me till now. I pick it up on Friday and it has the V10m 4" Pro-Comp Lift and 20" Rims (which will get changed back to the stock size with Off Road Tires. This is supper clean. It has a Security Module that the current owner wasn't concerned about getting fixed.
Well none of the Key Fobs work, The key Pad doesn't work, the unlock only unlocks or locks the current door and it ha that little red light on the dash. So my first question is "Is there anyone here that can give me some advise on getting this replace. He told me that it was behind the radio and he has someone try to fi it but they couldn't figure out to get the radio out. That doesn't seem to be very hard to do. I have read some post using a google search and some say they are dealer installed and can be anywhere and some say that the Dealer needs to program it and some say you can do it from the instructions.
Thanks for any help I can get.
David Phelps
Old Nov 23, 2019 | 08:52 AM
bluovl's Avatar
bluovl
Sure sounds like the VSM module. Have you checked to see if it's even plugged in? I'll bet the p.o. unplugged it.
Old Feb 21, 2020 | 10:47 PM
Joe Monaghan's Avatar
Joe Monaghan
Any info on the possible bad VSM?
I have a 2002 Excursion with a bad VSM. All the symptoms. Auto Lights ,radio ,keyless entry ,etc. Just wondering where to get a VSM. Can it be bench programmed?
Old Feb 21, 2020 | 11:05 PM
78CJ5's Avatar
78CJ5
I just got mine back from the Dealer Ship. They found a e place that remanufacturers them. I can ask them where they got it if your interested. It sure is nice to have all of the working.
David
dcchadwick
Mar 6, 2016 10:10 PM
Mowing Man
Mar 17, 2014 11:54 AM
jsers
Sep 29, 2012 04:00 PM
propguy
Apr 1, 2006 06:10 PM
rock113
Dec 23, 2005 05:50 PM
