Sponsored by: Real Truck
door ajar
Old Mar 31, 2006 | 12:24 AM
propguy's Avatar
propguy
Exclamation door ajar
i have a 2001 f-250 extended cab with a v-10 in it and i have a door ajar light on that keeps the intreior lights on and now the power locks will not work does anyone know what the heck is going on before i have to pay through the nose at the dealer?
Old Mar 31, 2006 | 02:03 AM
ryaneverk2's Avatar
ryaneverk2
The door ajar issue is very common. Try spraying a bunch of wd-40 in the door latches and working the doors open and shut a few times. The real fix is to replace the switches, but this cures things for a while for most people.
If the power locks won't work... it's possibly the actuators inside the door need replacing. Do a search on "actuators" in the Superduty section and you'll find some good info on doing that.
Old Mar 31, 2006 | 02:45 PM
propguy's Avatar
propguy
Thank you so much! it fixed everything and only cost me only 4 bucks.
Old Mar 31, 2006 | 03:17 PM
ryaneverk2's Avatar
ryaneverk2
It fixed your power door lock problem, too? How much WD-40 did you use, too... just curious.
Old Mar 31, 2006 | 03:21 PM
propguy's Avatar
propguy
about 10 seconds worth but it was a bad can it trickled out.but it still did the job.thanks again.
Old Mar 31, 2006 | 03:26 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
"but this cures things for a while for most people."
Actually, that "while" will probably be years!! You may never see that problem again. This has been a FORD problem for a lonnnnggggg time. My '97 Lincoln Mark VIII had that exact same problem 2 years ago. Used about 1/4 can of WD40 and have never seen the problem again......
Old Mar 31, 2006 | 03:34 PM
propguy's Avatar
propguy
don't you have the dust problem though?(where the wd-40 is)
Old Mar 31, 2006 | 07:30 PM
z01tde's Avatar
z01tde
[QUOTE=ryaneverk2]The door ajar issue is very common. Try spraying a bunch of wd-40 in the door latches and working the doors open and shut a few times. The real fix is to replace the switches, but this cures things for a while for most people.
Do you spray just the latches or the latches & the hinges? I'll spray a couple cans if I need to to get the lights to stop going off & on! It's driving me crazy. I have a '99 Crew Cab.
Old Mar 31, 2006 | 07:34 PM
jake00's Avatar
jake00
I sprayed the latches and where the door latch catches in the jamb
Old Mar 31, 2006 | 07:35 PM
ryaneverk2's Avatar
ryaneverk2
It's the part actually ON the door. There's the striker I guess it's called, on the door... you want the part that engages on that. It's in the door, with a sort of black lever/latch. The switch is inside there. So point the straw in there and give it hell. Open and close the door a bunch to work it in good, and it should fix it.....
Old Mar 31, 2006 | 08:29 PM
zx250's Avatar
zx250
Of the next Riffraff East
I sprayed mine with WD40 over 18 months ago. Door ajar light has not come back on unless the door is actually open. Now, as far as the door lock. Did you fix it with the spray? Where did you spray and did it get on you window glass. I have a lock that rarely works.
Old Apr 1, 2006 | 06:10 PM
z01tde's Avatar
z01tde
Thanks for the tip. I tried it and it worked right away. I knew I could find a fix here!
